Serial to USB cable - varying results
I would like to use a Serial to USB cable to communicate with a PiC16F688 which is running through an RS232 type level converter (actually an ICL2323). If I do straight serial communication with a com port on an older PC, everything works fine all the time. I can also communicate with a palm pilot, no problem. So I've established that straight serial works fine. But when I try serial to USB cables, the results vary from device to device. My first attempts failed utterly--I only got some periodic gibberish on the PC. A colleauge working with the same PIC-driven device also failed to establish communication, but then she tried a different (newer) PC and got it to work. I'm at a loss to see why there should be these discrepancies--serial to usb ought to be pretty simple right? Anyway, I was wondering if you had any insights because I have several people who will be using these devices, and I need to be able to recommend communication setups that work.
One possible clue is flow control. I tried setting up serial communication between a palm pilot and the PC using the serial to USB cable, and I could not get it to work until I messed around with the flow controls. Flow control is not necessary when doing straight serial communication between the same palm and PC.
end to end delays in USB/RS232 adapters
Bootloaders seem very time sensitive to the variable delays when using USB to RS232 converters. Colleagues and I have tried at least half a dozen different looking adapters with netbooks, laptops notebooks and desk PCs. NONE gave 100% reliable results. Some mostly work, some never work. They are all Chinese and are generally fine for dumb ASCII communications but whenever accurate timing between sending a character and getting a reply is needed then it's back to an old PC with dedicated RS-232 DB9 connectors.
It was my design practice to always fit an RS-232/TTL port to every design and use the MCSP bootloader for field bugfixes. I have abandoned that now and use the MeLabs U2 USB programmer for all code programming and updates. I have requested Mecanique to have a look at relaxing the timing on the MCSP bootloader but that message sank without trace.
HTH
Brian
