Memory Overflow? Urgently need advice
Hi guys, Im getting the message[306] crossing page boundary problem..
Im using a pic16F88 and it has a total amount of 9777+ asembly lines
Ive been googling and it seems that means that my pic16F88 has not sufficient memory to hold the program, however I feel like the program is very simple and straight forward.
So Im here looking for advice on ways to make the program fit onto my pic or should i get an 18X series. The code is approximately 257 lines but please give me an advice or two if possible! It will be greatly appreciated!
The main issue - without codeReset program, theres no memory overflow; with codeReset program it overflows
DEFINE OSC 8
OSCCON.4 = 1 'Sets the internal oscillator frequency to 8 MHz
OSCCON.5 = 1
OSCCON.6 = 1
'Turns off analog to digital conversion. Refer to
'Threaded Design Example A.4 p.296-299 of the textbook
'for an example of how to configure and use A/D conversion
'====End header for PIC16F88==========
'========knock.code=========
' picking up signal from microphone, and then indicating it through the LED
Include "bs2defs.bas" 'includes bs2 definitions for the xband motion sensor
'Pin Definitions
TRISA = %01011 'ports 0,1,3 are inputs & 2,4 are outputs
TRISB = %01101100 'ports 2,3,5 are inputs & rest are outputs
'PORTA's 'Keypad input and LCD output
ede1144 VAR PORTA.0 'transmit line from ede1144
ede1144Signal VAR PORTA.1 'valid line from ede1144
LCD VAR PORTA.2
xbandOutPin VAR PORTA.3 'x-band motion sensor output pin into PIC
xbandEnPin VAR PORTA.4 'x-band motion sensor input EN pin out of PIC
'PORTB's
buzzer VAR PORTB.1 'Buzzer alarm output
empty VAR PORTB.2 'unsure yet
arduin1 VAR PORTB.3 'arduino input
arduin2 VAR PORTB.4 'output to arduino
arduin3 VAR PORTB.5 'xband arduino output?
motor VAR PORTB.6 'motor output
'Variables.
LOW buzzer
'this is for the xband
motionThresh CON 2
cycles VAR word
reps VAR word
halfSecond CON 500
LOW xbandEnPin
'this is for counter
i VAR byte
'this is for the keypad
keyValue VAR byte
keyValue1 VAR byte
keyCode VAR byte[6] 'keycode array
keyCode[0] = $35 'initial keycode
keyCode[1] = $36
keyCode[2] = $36
keyCode[3] = $37
keyCode[4] = $36
keyCode[5] = $37
keyCodeInput VAR byte[6]
keyReceived VAR byte 'keypad input
keyReceived1 VAR byte
x VAR byte 'counter for number of tries
'power saving mode for LCD
SEROUT2 LCD,32,[$FE,$46 ] 'sends string to LCD to shut LCD
'main program
'xband motion sensor
HIGH xbandEnPin 'start the motion sensor when power is supplied
i = 0 'sets i as 0
If (arduin1 = 1) then motorOn 'if input detected from arduino ; code accepted goto motor
If (xbandEnPin == 1 ) then
COUNT xbandOutPin, halfSecond, cycles 'count the output from motion sensor
If (cycles > motionThresh) then
For i = 0 to 1
HIGH buzzer 'sound buzzer twice to show that motion has been detected
pause 150 'pause 0.2 secs
LOW buzzer
next i
SEROUT2 LCD,32,[$FE,$42,0 ] 'turns on LCD
goto lcdMenu
goto main 'loops back to main
endif:endif
'once motion has been detected, lcd starts
lcdMenu:
SEROUT2 LCD,32,[$FE,$40, "Welcome Home Mr. Mecha! ",$FE,$52 ] 'the startup message
SEROUT2 LCD,32,[$FE,$58, "Please Knock or Select Method of Input" ] 'the method of input is selected
SEROUT2 LCD,32,[$FE,$58,$FE,$52, "1) Keypad Code", $FE,$47,(1),(0), "2) Manually" ] 'turns on LCD
Serin EDE1144, 0, keyValue
If (keyValue = $30 ) Then keypadCODE
If (keyValue = $31 ) Then
serout2 LCD,32,[$FE,$58,"Welcome Home!",$FE,$52 ] 'message
pause 1500
'keypad entry
keypadCODE:
serout2 LCD,32,[$FE,$58,"Please enter 6-digit keycode",$FE,$52 ] 'ask for 6 digit keycombination
i = 0
if (keyValue != $46 ) then
if (keyValue = $30 )then
keyReceived = keyValue
if(keyValue = $31 )then
if(keyValue = $32 )then
if(keyValue = $33 )then
if(keyValue = $34 )then
if(keyValue = $35 )then
if(keyValue = $36 )then
if(keyValue = $37 )then
if(keyValue = $38 )then
if(keyValue = $39 )then
if(keyValue = $41 )then
if(keyValue = $44 )then
endif : endif : endif : endif : endif : endif : endif : endif : endif : endif : endif : endif :
keyCodeInput[i] = keyReceived
i = i + 1
serout2 LCD,32,[$FE,$58,"Code Entered, Please wait while it validates",$FE,$52 ] 'confirms entry
pause 150
For i = 0 to 1
LOW buzzer
next i
i = 0
for i = 0 to 5
if ( keyCodeInput[i] != keyCode[i] ) then revalidation
next i
serout2 LCD,32,[$FE,$58,"Would you like to set a new Combination?",$FE,$52 ] 'confirms entry
SEROUT2 LCD,32,[$FE,$58,$FE,$52, "1) Yes", $FE,$47,(1),(0), "2) No" ] 'turns on LCD
if (keyValue = $30 ) then
gosub codeReset
if (keyValue = $31 ) then motorOn
codeReset:
serout2 LCD,32,[$FE,$58,"Please input new combination up to 6 numbers",$FE,$52 ] 'confirms entry
i = 0
Serin EDE1144, 0, keyValue1
if (keyValue1 != $46 ) then
if (keyValue1 = $30 )then
keyReceived1 = keyValue1
if(keyValue1 = $31 )then
if(keyValue1 = $32 )then
if(keyValue1 = $33 )then
if(keyValue1 = $34 )then
if(keyValue1 = $35 )then
if(keyValue1 = $36 )then
if(keyValue1 = $37 )then
if(keyValue1 = $38 )then
if(keyValue1 = $39 )then
if(keyValue1 = $41 )then
if(keyValue1 = $44 )then
keyCode[i] = keyReceived1
i = i + 1
serout2 LCD,32,[$FE,$58,"Stored succefully! ",$FE,$52 ] 'confirms entry
For i = 0 to 1
HIGH buzzer 'sound buzzer twice to show that entry code is a success
pause 150 'pause 0.15 secs
LOW buzzer
next i
revalidation:
x=0
serout2 LCD,32,[$FE,$58,"Error, Please re-enter 6-digit keycode",$FE,$52 ] 'ask for 6 digit keycombination
HIGH buzzer
pause 150
LOW buzzer
if( x < 3 ) then
x = x + 1
goto keypadCODE
serout2 LCD,32,[$FE,$58,"INTRUDER ALERT!! INTRUDER ALERT!!",$FE,$52 ]
For i = 0 to 10
HIGH buzzer
pause 150
LOW buzzer
next i
'motor setup
motorOn:
HIGH motor
LOW motor
pause 2000
