help with error checking GPS data over audio link
I am sending GPS data over an audio link using a modem ic. On the TX side I have broken down the GPS data and I’m sending just the speed, heading and altitude. If it matters, I’m dropping the decimal numbers and only working with whole numbers to make things easier to convert later. My problem is that the wireless link is not the best and the data gets corrupted at times. What I’m doing is sending the speed, heading and altitude three times to the RX unit then I want to compare them against each other. Since my GPS updates every 2 seconds there are no issues with timing. I am successfully sending the data to the RX unit then outputting to the PC now. I just don’t know the best way to compare the data or the best format to send it. Eventually my plan is to send it to a LCD not a PC. At this time the program consists of three serin2 (1200bps) lines, one for each $1, $2, and $3; then three serout2 (4800bps) commands to view the data. It would be great if I could compare the speed, heading and altitude individually rather than the whole line. I don’t mind if I drop a couple of updates here and there I just don’t want to display garbage on the screen. Any help would be greatly appreciated.
Best regards,
Mark
Here is the format it is sent/received in. I am planning to change the 1,2,3 to A,B,C;
$1,speed,heading,altitude
$2,speed,heading,altitude
$3,speed,heading,altitude
Here is a snippet of some actual data transmitted to the receive unit and output to the PC. As you can see it makes it through 2 out of 3 times most of the time.;
$1,2,351,334
$2,2,351,334
$3,2,¦Sbššâj
$1,2<357,334
$2,2,357,334
$3,2,357,334
w¿ñ$1,2,355,¦&SHø
$2,2,355,334
$3,2,355,334
ÿ$1,1,353,333
$2,1,353,333
$3,1,353,333
$1,1,35Miššj
$2,1,355,333
$3,1,355,333
$1,1,11–¦&¦Hø
$2,1,11,332
$3,1,11,332
ø$1.1,29,332
$2,1,29*332
$3,1,29,33-
ã
