DS1307 RTC - Advice please.
Hi Guys and Gals,
I'm trying to the the RTC2 module (see image below) working on my EasyPIC5 board.
http://www.mcustore.com/acatalog/rtc2_150.jpg
I've scoured this forum, and trawled the web for various examples but still can't get the date and time displayed on the LCD. My guess is that I'm either missing something in the port config (can't say I can understand the datasheet but is seems that you don't need to set any fancy register) or the module has developed a fault.
The following code compiles fine and loads on the target chip (16F877a). It runs but displays 00/00/00 00:00:00 on the LCD.
@ __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
DEFINE OSC 20
CLEAR
;----[LCD definitions]------------------------------------------------------
DEFINE LCD_DREG PORTB ' LCD Data port
DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4)
DEFINE LCD_EREG PORTB ' LCD Enable port
DEFINE LCD_EBIT 5 ' Enable bit (on EasyPIC 5 LCD)
DEFINE LCD_RSREG PORTB ' LCD Register Select port
DEFINE LCD_RSBIT 4 ' Register Select bit (on EasyPIC 5 LCD)
DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 4 ' number of lines on LCD
DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
DEFINE LCD_DATAUS 50 ' Data delay time in us
'RTC pins on 877a
SDA Var PORTC.4
SCL Var PORTC.3
' Allocate variables
RTCYear Var Byte
RTCMonth Var Byte
RTCDate Var Byte
RTCDay Var Byte
RTCHour Var Byte
RTCMin Var Byte
RTCSec Var Byte
RTCCtrl Var Byte
' Initialize LCD
LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250
' Set initial time to 8:00:00AM 06/21/05
RTCYear = $10
RTCMonth = $03
RTCDate = $22
RTCDay = $02
RTCHour = $12
RTCMin = 0
RTCSec = 0
RTCCtrl = 0
Gosub set ' Set the time
Goto mainloop ' Skip over subroutines
' Subroutine to write time to RTC
set:
I2CWrite SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
' Subroutine to read time from RTC
gettime:
I2CRead SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
mainloop:
Gosub gettime ' Read the time from the RTC
' Display time on LCD
Lcdout $fe, 1, hex2 RTCMonth, "/", hex2 RTCDate, "/" , hex2 RTCYear,_
" ", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
Pause 500
Goto mainloop
The chip is using a 20Mhz xtal if that has any bearing on the issue, but I guess I should still be able to read and write to the DS1307 if the timing was out ?
