subroutine for picbasic
hi i want to make a subroutine for checking the status of each bit of portb and set a high on corresponding to porta.
here is the assembly code
checking portb
btfsc portb, 0
bsf porta, 0
btfsc portb, 1
bsf porta, 1
btfsc portb, 2
bsf porta, 2
btfsc portb, 3
bsf porta, 3
please help me to translate this code into picbasic pro
appreciate for any help
OK, let me get this straight. You want your program to do the following:
check if portb.0 is high, if so set porta.0 high and so on?
If that's the case, then it's pretty easy,
IF PORTB.0 = 1
THEN PORTA.0 = 1
ELSE PORTA.0 = 0
IF PORTB.1 = 1
THEN PORTA.1 = 1
ELSE PORTA.1 = 0
IF PORTB.2 = 1
THEN PORTA.2 = 1
ELSE PORTA.2 = 0
IF PORTB.3 = 1
THEN PORTA.3 = 1
ELSE PORTA.3 = 0
That is the bulk of what I think you are trying to do. You will have to set the TRISB registers to outputs. In addition, I don't know how fast you would want these changes to occur, so I would see if you could get something like this up and running and check to see if the speed meets your requirements.
more easy than if then stuff...
TRISA=0 'output on all PORTA pin
TRISB=255 'Input on all PORTB pin
CheckingPORTA:
PORTA=PORTB
1 line do everything ;)
hi Turbols
appreciate your help i am trying to use in pic16f877a by checking each bit and send a high to porta to activate a relay.
MyInput var Byte
TestLoop var byte
Start:
MyInput = PORTA
For testloop = 0 to 7
PORTB.0[testloop]=Myinput.0[TestLoop] ' send the state of the bit to
' the according PORTB bit
next
goto start
