Question on crystal selection: parallel vs series cut
Upon reading the specs of the 18F1320 PIC that I'm using, it says I need a parallel cut crystal. When I go on Digikey, I see lots of crystals such as the HC49/US but I don't see any mention of the crytals being parallel cut. I'm planning on using an 8Mhz crystal. I'd use the internal oscillator but the PIC is going to be outside in fluctuating temperatures. In any event, should I just assume an 8Mhz HC49/US crystal from digikey is a parallel cut crystal?
Hoping you can point me in the right direction.
Eric
Thanks to Melanie, Ioannis, et all for your help
Thanks for your help! The PIC is going to be used for serial communication at a 9600 baud rate so I should be good. I was not aware of the critical role that these small capacitances played in the crystal's performance. (Now I know) That crystal oven seems like an interesting idea for possible future timing applications. Thanks again.
Eric
