New and looking for help
Hello Everybody,
I have written a program for a PIC 16F685. I can't get it to work. It should read the pressure from a sensor (it does), indicate via LCD the voltage as converted (it does), light up an led for on pressure, high pressure, or low pressure (it does), and then move a servo accordingly (the servo buzzes but no consistant movement). I have read several books and still dont' understand the a/d conversion commands I simply copied them, perhaps there is my problem but I can't figure out how to get it fixed. If I play around with the commands, or the Physical and porgrammed location of the servo, I can sometimes get the servo to work, but then the LED's stop working. After a week of trying to figure it out it is time to humbly admit defeat and ask for help. I will eventually want to add a couple buttons to control the logic, but I need to get this workign first. Any help is greatly appreciated, and below is my current code:
'* Name : pressure reader.BAS *
'* Author : [Leon Wilde ] *
'* Notice : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 8/23/2009 *
'* Version : 1.0 *
'* Notes : *
Include "modedefs.bas"
' variables
res var word ' a/d converter result
volts var word ' result of converersion in mV
width var word
servopos var word
conv con 19 '5000/256=19.53, take 19
TRISA = 1 ' RA0 (an0) is input
TRISB = 0 ' RB AS OUTPUT
TRISC = 0
LED1 var portB.6
LED2 VAR PORTB.5
LED3 VAR PORTB.4
servo var portb.7
DEFINE ADC_BITS 8 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
ADCON1 = 2 ' PORTA is analog
clear
SERVOPOS = 150
pause 10
'initialization
for width = 1 to 100
pulsout portC.6, SERVOPOS
pause 10
next
pause 10
serout portc.7, 2400, [12,1,14] ' CLEAR SERIAL LCD
start:
PAUSE 10
pulsout portC.6,servopos
pause 10
next
LED1 = 0
LED2 = 0
LED3 = 0
PAUSE 10
' START A/C CONVERSION
ADCIN 0, res ' Read channel 0 to res
'WAIT UNTIL CONVERSION IS COMPLETE
VOLTS = RES * CONV
serout portc.7, 2400, ["V=", #VOLTS]
if volts < 1040 Then goto tooshallow
IF VOLTS > 1066 THEN goto toodeep
goto goodpressure
PAUSE 1000
GOTO start
tooshallow:
LED1 = 1
servopos = 50
goto start
goodpressure:
LED2 = 1
servopos = 100
goto start
toodeep:
LED3 = 1
servopos = 150
goto start
No expert, but I think your problem is in the servo drive timing. A standard RC servo requires a pulse between 1ms and 2ms (1.5ms represents centre stick) repeated every 20ms. It looks like you are simply sending a value of 50 or 100 which is on the limits or outside its range, and you are not repeating this within the 20ms time frame.
There are plenty of examples on the forum for servo drivers, have a go at getting your hardware working with one of those and then use that as the driver for your project.
Here are some examples:
http://www.rentron.com/servo.htm
http://www.rentron.com/SerialServo.htm
this is something I did for the grand kids one day (just grab the file had not recheck
to make sure it still works)
thought it mite help you it uses a A/D to drive a servo
remember I'm not a pro. just a hobbyist
'* Name : LIGHT BOX.BAS *
'* Author : grounded *
'* Notice : Copyright (c) *
'* Date : 3/12/2007 *
'* Version : 1.0 *
'* Notes : IF YOU SHINE A LIGHT ON THE PHOTO CELL THE BOX OPENS
'* : AND STAYS OPEN UNTIL THE LIGHT IS REMOVED
pic16f676 'fuses set in inc file
'INTRC_OSC_NOCLKOUT, WDT_ON, MCLR_OFF,
'CPD_OFF, BOD_OFF, PWRT_ON,PROTECT_OFF
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
Pause 7000 'DELAY TO LET STABILIZE AFTER POWER UP & MODE
CMCON = 7 'COMPARATOR OFF
VRCON = 0 'VOLTAGE REF. DISABLE
TRISA = %00001101 'MAKE A.2 & A.3 INPUTS
TRISC = %00000011 'MAKE .C.0,C.1 PORTC INPUTS
ANSEL = %00000001 'PORTA.0 A/D IN,RST DIGITAL
ADCON0.7 = 1 'RIGHT JUSTIFY FOR 10 BIT
OPTION_REG=%01000000 'RAISING EDGE/WEAK PULL UP
WPUA = %00000000 'NO WEAK PULLUPS
SYMBOL ADC =PORTA.0 'ADCIN
SYMBOL LDR =PORTA.1 'PHOTO POWER
SYMBOL PIR =PORTA.2 'PIR TRIPS HIGH
SYMBOL MODE =PORTA.3 'MODE BUTTON
SYMBOL smA =PORTA.4 'SERVO CONTROL OUTPUT
SYMBOL LED =PORTA.5 'WALKTEST AND POWER LED
SYMBOL DIPB =PORTC.0 'DIP SWITCH 2 N/A
SYMBOL DIPA =PORTC.1 'DIP SWITCH 1 N/A
SYMBOL DPO =PORTC.2 'DIP SWITCH POWER N/A
SYMBOL RL =PORTC.3 'N/A REMOTE LIGHT N/A
SYMBOL CPO =PORTC.4 'CAM POWER BUTTON N/A
SYMBOL RC =PORTC.5 'RECORD BUTTON N/A
'****************************SET UP VARIBLES***************************
NIGHT VAR WORD:NIGHT=0 'LDR/ADCIN VAR FOR LIGHT SENSOR
'********************************TURN EVERYTHING OFF*********************
ADC=0:LDR=0:PIR=0:MODE=0:smA=0:LED=0:DIPA=0:DIPB=0:DPO=0:RL=0:CPO=0:RC=0
'************************************ CAL MODE*******************
led=1 :pause 3000 :led=0
IF MODE=0 Then GoTo CAL 'IF MODE BUTTON =0 THEN GOTO LRD CAL MODE
GoTo MAIN 'SKIP CAL MODE GO MAIN
CAL:
LDR=1:Pause 250 'TURN LDR/ADCIN POWER ON
LED=1:Pause 250:LED=0:Pause 250
LED=1:Pause 250:LED=0:Pause 1000 ' FLASH YOUR IN CAL MODE
TEST:
NIGHT=0
LED=0
ADCIN 0,NIGHT 'CHECK AN# READ AN1 & STORE IN NIGHT VAR
IF NIGHT=<200 Then LED=1 'IF LED IS ON THEN IT'S LIGHT ENOUGHT TO OPEN BOX
Pause 250
IF MODE =0 Then GoTo main 'LEAVE CAL MODE
GoTo TEST 'LOOP AND CHECK FOR LIGHT AGAIN
asc var word : asc=70
ldr=1
NIGHT=0
LED=0
pause 250
if night =< 200 then goto open
open
PULSOUT SMA,asc
PAUSE 18
ASC=ASC+1
if ASC=>240 THEN PAUSE 2000: GOTO shut
GOTO open
shut:
NIGHT=0
pause 20
pause 20
if night => 200 then goto close
goto shut
close
led=0
PULSOUT SMA,asc
PAUSE 18
ASC=ASC-1
if ASC=<65 THEN PAUSE 2000: GOTO main
GOTO close
Thanks, guys, now to add some buttons and play with the logic portion
