fatal error out of memory (pbpw.exe)
Hi All,
I have two computers one is running on Win98SE and second Win XP pro.
Both of them have the same PIC BASIC PRO v.2.50b.
The first is running PIC Basic Pro well. On second I get message fatal error
out of memory (pbpw.exe).
I checked PM.EXE properties and found 8 Tabs:
General
Program
Font
Memory
Screen
Misc
Compatibility
Summary.
Pbpw.exe has only 4 Tabs:
General
Version 2.5.0.2 Copyright 1998
Compatibility
Summary.
So I think that problem is with old Pbpw.exe file because right now 2010
and new computer does not recognize old components due to constant updates from Microsoft and from other companies.
My Win XP computer has 2 Gb memory,2.4Ghz double core processor so it is enough space to work with different applications.
How I can solve my problem?
Or Pbpw.exe will be re-writes WinXP enviroment?
Or better to install Linux OS?
It is really bad to spent a money for PIC BASIC Pro compiler for nothing.
What you think about my situation?
Looking in message board I found that many users with Win XP have similar problem.
Best Regards,:confused:
Leon
Problem is the old handler suited for 16 bit applications
Hi All,
Thank you for your advice it does not works.
When I open Pbpw.exe property in Win98SE machine I found only 3tabs.
WinXP generate compatibility 4th tab by itself so it is empty.
High probability is that the handler in Pbpw.exe is Win16 (1997). NOTHING is changed except the handler itself. So at the next release and thereafter, Pbpw.exe will use the Win32 Installer. This is a subtle hint that, like DOS, Microsoft is slowly dropping Win16 apps!
Now developers who are working with PICBASIC Pro codes have to say something because next generation of 32 or 64 computer will be unable to work with PICBASIC PRO at all.
Best Regards,
Leon:mad:
fatal error - Case solved
Hi All,
Due to your recommendations I start clearing my computer from programs that I am not using (were installed as trial versions) .
When I deleted microBasic trial version from microElectronica problem with pbpw.exe vanished and I am able to use PICBASIC pro again.
Here is some aggressive correlation between of two programs.
Big thanks to All for sharing thoughts that help to solve the problem.:cool:
