2 Pics, different baud rates needed
		We have
1 PIC18F2550
1 PIC18F2423
Config 2550
@        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
@        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
@        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_3_2L & _VREGEN_ON_2L
@        __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
@        __CONFIG    _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
@        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
@        __CONFIG    _CONFIG5L, _CP0_OFF_5L   & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
@        __CONFIG    _CONFIG5H, _CPB_OFF_5H   & _CPD_OFF_5H
@        __CONFIG    _CONFIG6L, _WRT0_OFF_6L  & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
@        __CONFIG    _CONFIG6H, _WRTB_OFF_6H  & _WRTC_OFF_6H    & _WRTD_OFF_6H
@        __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L  & _EBTR2_OFF_7L   & _EBTR3_OFF_7L
@        __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
DEFINE OSC 20
DEFINE CHAR_PACING 1000
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 20h
DEFINE HSER_BAUD 2400
DEFINE HSER_CLROERR 1
 Config 2423
@        __CONFIG    _CONFIG1H, _OSC_HS_1H    & _FCMEN_OFF_1H   & _IESO_OFF_1H
@        __CONFIG    _CONFIG2L, _PWRT_ON_2L   & _BOREN_OFF_2L & _BORV_1_2L
@        __CONFIG    _CONFIG2H, _WDT_OFF_2H   & _WDTPS_1_2H
@        __CONFIG    _CONFIG3H, _MCLRE_ON_3H  & _LPT1OSC_OFF_3H  & _PBADEN_OFF_3H & _CCP2MX_PORTC_3H
DEFINE OSC 20
DEFINE DEBUG_REG PORTC
DEFINE DEBUG_BIT 6
DEFINE DEBUG_BAUD 19200
DEFINE DEBUG_PACING 100
DEFINE DEBUGIN_REG PORTC
DEFINE DEBUGIN_BIT 7
DEFINE SER2_BITS 8
DEFINE HSER_BAUD 6000
 Code Example:
preprogramloop:
IF OtherPICconnected THEN ' check a I/O-pin
    'PAUSE 50
    HSERIN 1000, preprogramloop, [WAIT("#"), STR SeriellBuffer\2]
    IF SeriellBuffer[0] = "X" AND SeriellBuffer[1] = "X" THEN
        HSEROUT ["@OK"]
        GOTO Docked
    GOTO preprogramloop
 We measured the 2550 + 2423 TX lines with an oscilloscope until we found a HSER_BAUD rate that matched and we got no problem communicating between those two PICs.
Does it make any sense that those two HSER_BAUD settings differ?
