PIC16LF819 A/D problem
Having a small problem with the PIC16LF819 trying to measure a 3-5V on RA0. I can't seem to get the program to run into loop4 the program keeps seeing it in loop 5 with the measurement of 4.995V it can't seem to change/read it when the voltage drops to 4.7V or 4.3V, or even below 4 and 3V, any ideas why?,
My code looks like this:
Define OSC 4 ' Set Xtal Frequency
' ** Setup the Debug Defines **
' ** Declare the Variables **
Define ADC_CLOCK 1 ' Set clock source (3=rc)
AD_Raw VAR WORD' 10-bit result of A/D conversion
AD_Result VAR WORD' Quantasized ADC result
Average VAR WORD' Variable for building up the average result
Samples VAR BYTE' Amount of samples taken
Volts VAR BYTE' Holds the Volts part of the result (only for display purposes)
Millivolts VAR WORD' Holds the Millivolts part of the result (only for display purposes)
adval VAR WORD' Create adval to store result
Quanta Con 1250
Adcon1 = 7
TRISA = %00000001
goto start
START:
high portb.0
low portb.1
low portb.2
Average=0 ' Clear the Average variable befor use
For Samples=0 TO 9 ' We will take 100 samples of the ADC
ADCIN 0,AD_Raw ' Place the conversion of channel0 into AD_RAW
Average=Average+AD_Raw ' Build up the Average result
Next ' Close the loop
Average=Average/10 ' Calculate the average by dividing by the number of samples taken
AD_Result=(Average) */ Quanta' Quantasize the result
Adval=AD_Result
volts = ad_result / 1000
millivolts = ad_result // 1000
if volts = 0 then goto loop2
if volts = 1 then goto loop2
if volts = 2 then goto loop2
if volts = 3 then goto loop2
if volts = 4 then goto loop3
goto start
loop2:
high portb.0
high portb.1
low portb.2
goto start
loop3:
if millivolts < 995 then goto loop4
if millivolts > 995 then goto loop5
goto loop3
loop4:
high portb.0
high portb.1
low portb.2
goto start
loop5:
high portb.0
low portb.1
high portb.2
goto start
