Simple USB Comms Problem
Hi all,
I am trying to get a USB Project going but have hit a brick wall.
I am using Picbasic Pro 2.50a with microcode Studio. I used EasyHID wizard to create the template files and to check all was well before continuing I set it up to continually send some bytes over USB and used Darrel Taylors HID monitor to check what was being received.
What I can't figure out is that despite trying to send some characters all I get in HIDMonitor is 8 bytes of 0x00. The device is enumerated OK and remains connected but the data just does not get through.
Its driving me absolutely insane because I have code a lot more complicated than this that works fine. The code is below, if anybody can offer some assistance that would be great!
Andy
' PIC Configuration Bits
asm
__CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
; ; ; USB clock source comes from the 96 MHz PLL divided by 2
; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
; No prescale (4 MHz oscillator input drives PLL directly)
__CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
; ; ; Oscillator Switchover mode disabled
; ; Fail-Safe Clock Monitor disabled
; XT oscillator, PLL enabled, XT used by USB
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
__CONFIG _CONFIG2H, _WDT_OFF_2H
__CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_OFF_3H
__CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L ;& _ICPRT_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
endasm
DEFINE OSC 48
USBBufferSizeMax con 8 ' maximum buffer size
USBBufferSizeTX con 8 ' input
USBBufferSizeRX con 8 ' output
' the USB buffer...
USBBuffer Var Byte[USBBufferSizeMax]
USBBufferCount Var Byte
' Used by USB initialisation:
usb_device_state var byte EXT
CONFIGURED_STATE CON EXT
' Used in USB Comms
IDLEIF VAR UIR.4
SOFIF VAR UIR.6
Plugged VAR BIT
i var byte
' Hardware configuration
TRISA = 0 ' all outputs
TRISB = %00010000 ' only RB4 as input so others are excluded from IOC
TRISC = 0 ' all outputs
PORTA = 0 ' set all LEDs off at startup
PORTB = 0
' A/D converter
ADCON0 = %00000000 ' A/D converter module disabled
ADCON1 = %00001111 ' PORTA all digital signals
' USB module
ucfg = %00010100 ' enable internal USB pull-up, Full speed USB
PORTA.1 = 1
' * main program loop - remember, you must keep the USB *
' * connection alive with a call to USBService every couple *
' * of milliseconds or so... *
usbinit ' initialise USB...
repeat ' kick-start it by performing a tight loop of servicing until the USB
' state is CONFIGURED
usbservice
until usb_device_state = CONFIGURED_STATE
PORTA.1 = 0
PORTA.0 = 1
ProgramStart:
'gosub DoUSBIn
toggle PORTA.2
for i = 1 to 10000
USBSERVICE
pause 2
next i
gosub DoUSBOut
goto ProgramStart
' * receive data from the USB bus *
DoUSBIn:
USBBufferCount = USBBufferSizeRX ' RX buffer size
USBService ' keep connection alive
USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
' * wait for USB interface to attach *
DoUSBOut:
USBBufferCount = USBBufferSizeTX ' TX buffer size
USBBuffer[1] = "a"
USBBuffer[3] = "F"
USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
USBSERVICE
