strange serout2 problem
Hi everyone, and happy new year :)
I am trying a rs232 communication. I use 16f84a. I am a beginner in electronics.
This problem seems strange:
I use hyper terminal. I have a Max232 circuit with Sub-D 9-F. I also send the schematic of the circuit (my source is http://sodoityourself.com/max232-ser...vel-converter/ )
Here is the problem, controller led is blinking but there is nothing on hyper terminal
OutGoing VAR Byte
OutGoing = "K"
D_Forwarder VAR PORTB.3 'data forwarder
Forwarder VAR PORTA.1 ' Controller led
PAUSE 500
SEROUT2 D_Forwarder,396,["O",OutGoing ] '2400 baud rate
HIGH Forwarder
PAUSE 100
LOW Forwarder
But in this code, while the led is blinking i also see both of the O and K characters, it works.
OutGoing1 VAR Byte
OutGoing1 = "K"
OutGoing2 VAR Byte
OutGoing2 = "S"
D_Receiver PORTB.2 'data receiver
Receiver VAR PORTA.0 ' Controller led
PAUSE 500
SEROUT2 D_Forwarder,396,["O",OutGoing1 ] '2400 baud rate
HIGH Forwarder
PAUSE 100
LOW Forwarder
SEROUT2 D_Receiver ,396,["O",OutGoing2 ]
HIGH Receiver
PAUSE 100
LOW Receiver
Is this correct?
This line in the program you say works should cause the program to not compile.
You forgot the VAR.
I erased it accidently, sorry :) There is a VAR over there, it compiles.
