How to read PIC serial no. from EEPROM with PBP?
I understand that Microchip has written the serial number of the chip into EEPROM for 18Fxxxx chips and that it can be read by PBP code. Can anyone tell me where in the chip memory map of a 18F4550 the serial no. is located and how to use PBP code to read it? I would like to use this as a method of uniquely identifying the location/ID of each embedded processor application that contains one of these chips.
Where are the serial number bits?
Bruce
The Special Features section of the data sheet shows the device ID locations.
Thanks, Bruce, for the code on how to get to the DEVID info. I had seen the DEVICE ID register in the data sheet but didn't see any of the 14 bits that were actually providing a serial number of the individual chip. That is what I am after. From the data sheet DEVID only provides device type (DEVID1<7:5>, device revision(DEVID1<4:0>, device part number (DEVID2<7:0>, none of which appear to be a unique serial number.
Is my information incorrect that there is a unique serial number somewhere in the chip? I was led to believe it was in there by the following statement in the 18F4550 data sheet:
"17.10.6.1 Device Descriptor
The device descriptor provides general information,
such as manufacturer, product number, serial number,
the class of the device and the number of configurations."
This statement doesn't seem to correlate with the DEVID register description in the same data sheet , so if there is a serial number in there it is well hidden in the data sheet info.
