Problems setting INTCONx registers in 18F4550
I am coding for a PIC 18F4550 with PBP 2.6. I need to set some of the bits in the INCON2, INCON3 and RCON registers and keep getting syntax errors at compile time for the following statements. As far as I can see in the Datasheet and the PBP manual these are correct syntax yet the errors. Can anyone tell me what is wrong with these?
' Interrupts Settings
RCON = %10000000 ' Set Interrupt Priority Enable bit (Bit7=IPEN)
' to enable priority levels on interrupts
INTCON.7 = 1 ' Set Global Interrupt Enable bit
INTCON2.7 = 1 ' Enable PORTB Pull-ups (Bit7-high), set INT2 for
' falling edge (Bit4-low) on RTC's interrupt.
INTCON3 = %10010000 ' Set INT2 high priority (Bit7-high), enable INT2
' (Bit4-high)
RTC_INT_FLG VAR INTCON3.1 'Alias for RB4 INTA interrupt from RTC
Duhh...that was it...senior moment!
Bill Legge
have you selected the chip type as 18F4550 in the 'chip select' box?
Thanks, Bill. . Even experienced programmers have their senior moments. I should have looked at the device setting all along
