Need help with LM34 and 12F675
I'm trying to build a fan controller for a solar heater that I built but I can't seem to get it to work. I've tried everything I can think of and now I need help.
Yes probably that kind too. I was sane before I started this.
I'm using an LM34 temperature sensor which outputs 10mv/deg F from 5F (50mv) to 300F (3000mv) and a 12F675.
Attached is a text file with the code and it is also listed below.
Any help would be appreciated. I'm trying to make it come on at 115F and go off at 80F, settable in a constant at the beginning of the code. Later I want to add PWM for servo operated dampers.
Any help will be appreciated.
'Modified from file found at Renolds Electronics
'http://www.rentron.com/PIC12C67XAD.htm
'LM34
'PIN NAME Purpose
' 1 VDD +5v
' 2 Output 10mv/degF, +5° to +300°F = 50mv-3000mv
' 3 VSS GND
'PIC12F675
' PIN NAME Purpose
' 1 VDD +5v
' 8 VSS GND
' 5 GPIO.2 PWM out to servo
' 6 GPIO.1 Output to NPN transistor sinking relay.
' 7 GPIO.0 A/D input from center leg of LM34
'******************* Fuses, Defines, Variables & Constants ******************
@ device pic12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off, protect_off
define OSC 4 'Use 4mhz osc
CMCON=7 '(%00000111) Turn off analog comparators
TRISIO=%001001 '(Dec 9)Port direction register. 1=input, 0=output Note TRISIO.3 is always an input.
RESULT VAR BYTE 'A/D CONVERSION RESULT STORAGE BYTE
ADCON1=6 '(%00000110) SET GP.0 TO ANALOG INPUT, Vref = Vdd, ALL ELSE = DIGITAL I/O
HighTemp var byte 'High temperature setpoint
LowTemp Var byte 'Low temperature setpoint
Relay var GPIO.1 'Output pin tp transistor
'PWMOut var GPIO.2 'Pin 5 used to drive damper servos 'To be implemented later
HighTemp = 115 'Relay turn on Temp
LowTemp = 80 'Relay turn off temp
'************************ Main ************************
MAIN:
GOSUB GETVAL 'SETUP A/D
pause 500 'Wait 500ms
gosub Setrelay 'Turn on or off relay
GOTO MAIN 'Start over
GETRESULT:
PAUSEUS 50 'WAIT FOR A/D CHANNEL SETUP (50 uS)
ADCON0.2 = 1 'START CONVERSION BY SETTING GO/DONE-BIT (HIGH)
LOOP: 'WAIT FOR GO/DONE BIT TO BE CLEARED
IF ADCON0.2=1 THEN 'CHECK GO/DONE BIT (0=DONE)
GOTO LOOP 'NOT FINISHED CONVERTING, THEN LOOP UNTIL DONE
ENDIF 'IF STATEMENT SATISFIED, ADCON0.2 = 0 (DONE)
RETURN 'FINISHED CONVERSION, RETURN TO GETVAL ROUTINE
GETVAL:
ADCON0=%10000001 'SET A/D Fosc/32,[4MHz], CHANNEL-0 = ON
GOSUB GETRESULT 'START THE CONVERSION
RESULT = ADRES 'STORE THE A/D CONVERSION VALUE IN RESULT
RETURN 'RETURN TO MAIN ROUTINE, START OVER
SetRelay: 'Turn on or off relay with hysterisis
select case RESULT
case RESULT <= lowTemp
low relay
'PWM GPIO.2, 127, 100 'Need 1ms wide pulse at about 40-50 per second. To be implemented later
case RESULT > LowTemp and Temp > HighTemp
low Relay
'PWM GPIO.2, 25, 100 'Need 1ms wide pulse at about 40-50 per second. To be implemented later
end select
'PWM GPIO.2, 127, 100 'Send 50% (127) duty cycle pwm signal out pin 5 for 100 cycles
