ABS brake Pic code with 16f917 mcu
We have made a construction for a mechatronic course. The construction is like this:
http://i7.photobucket.com/albums/y29...ABS_Bremse.png
Our problem is simply the code for the 16f917 mcu, which we are gonna program with pic code.
We need to convert the analog signal from the electric motor (tachometer), to digital signal. The axel will be powered by a drilling machine. The digital output should be computed and the solenoid should react to that input.
Like if the digital signal reads zero very quickly (quick deacceleration), the solenoid should brake with a pulse to prevent the "wheel" from blocking. And if the axel doesnt spin and you brake, the solenoid shouldnt brake with a pulse, but just normal.
We have completly newbs at this, and understand absolutely nothing, so plz we would appreciate language that everyone understands :)
If someone knows of a website or something else, plz link to it :P
Thx in advance :)
when the blind one doesn't want to Hear ...
Hi Foodie ...
You do not understand at all , I think ...
A SUPPORT forum is to help people to understand the compiler use ...
NOT to give them " ready to burn " programs ...
Here, you are explaining What you want to see your MACHINE doing ...
so, Understand we also are totally newbies, and we do not understand anything to Physics, Mechanics Or Dynamics ... or even Solidworks, but ONLY informatics and electronics.
"Foucault" will be the extreme limit ...
That was exactlywhat done ... it seems. Was the only link returned by Google, BTW ...
And we dont understand french...
so, may be you can understand how translators work ???
A little ( just a little ...) effort from you is welcome ... isn't it ???
PS : that reminds me someone coming from Germany with surprising projects ... Pseudo was : "Selbstdual" ...
rePS: May be we ALSO could understand German ... with a little effort. Danish is too much ( Pastries only ... )
Other links :
http://www.conatex.com/mediapool/bet...AD_2003649.pdf
http://books.google.fr/books?id=CB9G...age&q=&f=false
