Using longs with PBP2.6
Is there something obvious which I am mising here ?
Previously, using PBP2.5, I could compile code using PBL when I had included variables of the long type by using the 'use pbl' option in the editor submenu.
but in PBP2.6 there doesn't seem to be an option in the editor menu to use PBL.
Hi, Chris
May I suppose you use MCS Editor ???
Still the Check box ... in the compiler/assembler options.
MPLAB :
It appears now located in the " Project\Build options " windowS ...
Thanks, is it possible that I have downgraded to an older version of MCS which doesn't offer the facility to invoke PBPL , because like I say, it isn't there in the version I just installed (V3.05 ? I think...)
My MCS Version also is 3.0.0.5 ...
ahhhh, those computers ... impossible tu trust them ...
The free version of MCS doesn't have the checkbox.
The full version MCSP does.
It's still possible to use PBPL with MCS, but if you have the full version make sure you're starting the right program.
<br>
