16F883 and Problems with HIGH statement
I started with PIC programming two days ago. The project is to make a tachometer for my car. I am using the pulsin statement and that is (finally) working as expected. I will use about 10 LED's to indicate the RPM. 800 RPM=1 LED, 1300 RPM=2 LED 1800RPM=3 LED etc.
The problem now is that when using the statement: HIGH PORTB.0 the port goes down again immidiately.. If I put a pause directly after it stays on however.
Is this normal??
My goal is that when the code enters the IF statement for say: 5000 RPM I want ALL the LED's "below" 5000RPM to be on.
Here is a copy of my code. I have removed some of the IF statements for better readability.
@ device pic16F883, INTRC_OSC_CLKOUT, BOD_OFF, PWRT_OFF, wdt_off, mclr_off, protect_off
DEFINE OSC 8 'set OSC value to 8MHz for instructions PAUSE, PAUSEus and SOUND
'VARIABLES declaration
'IF VARIABLES USED FOUR COUNTER GO OVER 256, USE WORD INSTEAD
puls_h VAR Word 'input high
puls_l VAR Word 'input low
rpm var word
'Setting registers
OSCCON = %01110001
ANSEL = %00000000 'choose digital i/o, val = 0
TRISA = %00000001 'set porta pins directions (1=input, high impedance)
TRISB = %00000000
PORTA = %00000000 'set port pins logic, A0 will be a default LOW with 100K WPD
PORTB = %00000000 'set port pins logic
PAUSE 1000 'let the power level stabilize if not already done
start:
PULSIN PORTA.0, 0, puls_l
PULSIN PORTA.0, 1, puls_h
rpm = puls_l+puls_h
IF (rpm > 600 AND RPM < 2000) THEN
HIGH PORTB.0
'PAUSE 500 When I use this pause the LED will be lit 500ms here
LOW PORTB.1 'Without the pause the LED's flash fast and very dim.
LOW PORTB.2
LOW PORTB.3
GOTO START
IF (rpm > 2000 AND RPM < 4000) THEN
HIGH PORTB.0
HIGH PORTB.1
LOW PORTB.2
LOW PORTB.3
GOTO START
IF (rpm > 4000 AND RPM < 6000) THEN
HIGH PORTB.0
HIGH PORTB.1
HIGH PORTB.2
'pause 500 When I use this pause the LED will be lit 500ms here
LOW PORTB.3
GOTO START
IF (rpm > 6000 AND RPM < 8000) THEN
HIGH PORTB.0
HIGH PORTB.1
HIGH PORTB.2
HIGH PORTB.3 'When this code is active, the LED on portb.3 is lit.
GOTO START
GOTO START
END 'end of program
