Alright, I think I got a good one for ya here:
I have a large main program that is calling subroutines from an INCLUDE file (include "umfpuV3-spi.bas"). These subroutines use variables that are defined in the main program file. For some reason, the compiler (PBPro 2.46) does not recognize these variables when inside the INCLUDEd subroutines, and I get the error "Bad Expression".
These variables are PORT names, as shown in the code below. When I change the variable name to the PORTC.x name inside the INC file, the Main program compiles with no problem.
To be specific, when the GOSUB FPU_RESET is called in the main program below, the FpuOut, FpuClk, and FpuIn are not recognized in the subroutine.
Here is the header to my main program with the GOSUB:Code:'=============================================================================
' MAIN PROGRAM CODE
'-------------------- PIC oscillator speed ------------------------------------
define OSC 20 ' specify the speed of the oscillator
OSC_SPEED con 20 ' define PICBASIC constant
'-------------------- debug definitions ---------------------------------------
define DEBUG_REG PORTD
define DEBUG_BIT 0
define DEBUG_BAUD 9600
define DEBUG_MODE 0
DEFINE DEBUGIN_BIT 1
'-------------------- ADC CONFIG definitions ----------------------------------
Define ADC_SAMPLEUS 5 ' Set sampling time in uS
TRISA = %11111111 'Set PORTA to all input
'ADCON1 = %10001100 'config of 877
adcon1 = %00011000 'config for 4550
TRISD.3 = %1
'-------------------- INCLUDE files --------------------------------------------
Include "modedefs.bas" 'Include for serial communication
include "umfpuV3-spi.bas" ' include uM-FPU V3.1 support routines
include "fp1832.bas" 'Floating point math
'-------------------- uM-FPU pin definitions ----------------------------------
FpuClk var PORTC.3 ' SPI SCLK (uM-FPU SCLK)
FpuIn var PORTC.4 ' SPI MISO (uM-FPU SOUT)
FpuOut var PORTC.5 ' SPI MOSI (uM-FPU SIN)
'-------------------- AD7715 calibration data ----------------------------------
data @200, 0 'high byte of zs_mv
data @201, 0 'low byte of zs_mv
data @202, 0 'high byte of zs_adval
data @203, 0 'low byte of zs_adval
data @204, 4 'high byte of fs_mv
data @205, 237 'low byte of fs_mv
data @206, 233 'high byte of fs_adval
data @207, 188 'low byte of fs_adval
Reset:
DEBUG 13, 10, 13, 10, "Demo 2: "
GOSUB Fpu_Reset ' initialize uM-FPU
IF fpu_status <> SYNC_CHAR THEN
DEBUG "uM-FPU not detected."
GOSUB Print_Version ' display version string
*clipped*
Here is the subroutine inside the .inc file. You can see where I changed the first SHIFTOUT to use the PORT pin numbers, and the second SHIFTOUT is using the variable names.
Code:'==============================================================================
'-------------------- uM-FPU SPI support routines -----------------------------
Fpu_Reset: ' send reset command to uM-FPU V3
SHIFTOUT portc.5, portc.3, 1,_
[$FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, 0]
PAUSE 10
' check for synchronization
SHIFTOUT FpuOut, FpuClk, MSBFIRST, [SYNC]
GOTO Fpu_Status2
Here is a WORKING main program. When I compile this program, the subroutine recognizes the variables and has no errors:
So ... granted that my MAIN program is very large (25K) and has many other things going on, does anyone know what a possible problem or solution could be?Code:'=============================================================================
define DEBUG_REG PORTC
define DEBUG_BIT 6
define DEBUG_BAUD 19200
define DEBUG_MODE 0
'-------------------- DS1620 pin definitions ---------------------------------
DS_RST var PORTA.0 ' DS1620 reset/enable
DS_CLK var PORTA.1 ' DS1620 clock
DS_DATA var PORTA.2 ' DS1620 data
LSBFIRST con 0 ' shiftout mode
LSBPRE con 1 ' shiftin mode
'-------------------- uM-FPU register definitions ----------------------------
DegC CON 1 ' temperature in degrees Celsius
DegC_Min CON 2 ' minimum temperature
DegC_Max CON 3 ' maximum temperature
DegF CON 4 ' temperature in degrees Fahrenheit
F1_8 CON 5 ' constant 1.8
'-------------------- variables ----------------------------------------------
rawTemp VAR Word ' raw temperature reading
'-------------------- initialization -----------------------------------------
Reset:
DEBUG 13, 10, "---------------------"
GOSUB Init_DS1620 ' initialize DS1620
I'll be here all night...
