Need once your help one please
Hello
Need once your help one please.
Who can help me at the two following would cut off there I not point as I can write the one pic Basic.
To Thanks onto all of them in advance.
Btfss R_DATEN,0 ; immediately edition of the
bsf PORTB,B_OUT ; .. bits #0 of
btfsc R_DATEN,0 ; .. R daten at
bcf PORTB,B_OUT ; .. DATA_OUT
btfss PORTB,B_IN ; Bit at the entry
bsf STATUS,C ; .. DATA-IN to the
btfsc PORTB,B_IN ; .. To
bcf STATUS,C ; .. shift register into C
rrf R_DATEN,F ;To daten () negates
Who can follow me at would cut off ASM.......ENDASM help there I not point as I can write the one pic Basic.
Therefore everything what would like between ASM....and....Endasm I also still pic Basic have
S88.bas
B_CLK var PORTB.0 ' B_CLK to PORTB.0
B_OUT var PORTB.1 ' B_OUT to PORTB.1
B_LED var PORTB.2 ' B_IN to PORTB.6
B_IN var PORTB.6 ' B_IN to PORTB.6
B_PS var PORTB.7 ' B_PS to PORTB.7
R_DATEN var BYTE
asm
R_DATEN equ 20h ; fuer Speichern der Daten und Schieben
R_OLD equ 25h ; Register for old values
R_FLAG equ 26h ; Register for flags
F_PS_RDY equ d'1' ; Ready-Flag
A_X1 equ d'1' ; Port A7, X1
A_X2 equ d'0' ; Port A6, X2
A_X3 equ d'7' ; Port A5, X3
A_X4 equ d'6' ; Port A4, X4
A_X5 equ d'5' ; Port A3, X5
A_X6 equ d'4' ; Port A2, X6
A_X7 equ d'3' ; Port A1, X7
A_X8 equ d'2' ; Port A0, X8
B_CLK equ d'0' ; Port B, Clock
B_OUT equ d'1' ; Port B, Data-OUT
B_IN equ d'6' ; Port B, Data-IN
B_PS equ d'7' ; Port B, PS-Eingang
endasm
INTCON.0 =1 ;wenn RB0-Int(CLK) =1 dann
goto start ;gehe zu Start
INTCON.0 =0 ;wenn RB0-Int(CLK) =0 dann clear IR-Flag
asm
btfss R_DATEN,0 ; sofort Ausgabe des
bsf PORTB,B_OUT ; .. Bits #0 von
btfsc R_DATEN,0 ; .. R-Daten an
endasm
If B_CLK <>1 then
B_LED =0
toggle B_LED
If B_PS =0 then gosub lesen
asm
btfss PORTB,B_IN ; Bit am Eingang
bsf STATUS,C ; .. DATA-IN zum
btfsc PORTB,B_IN ; .. Nachschieben in
bcf STATUS,C ; .. Schieberegister in C
rrf R_DATEN,F ; Daten nachschieben (invertiert)
; ab hier sind die Daten in R_DATEN aktualisiert und fertig für
; die nächste pos. Flanke von CLK (#0 kann dann sofort an DATA_OUT
; weitergegeben werden).
endasm
start:
TRISB = %111110001 ' Set PORTB to output 0=Out 1=In
TRISA = %11111111 ' Set PORTA to input
CMCON = 7 ' PORTA to digital
OPTION_REG = $87 ' Konfiguration TIMER / WDT / Pull-Ups Disable PORTB pull-ups und PS2-PS0 Prescaler Rate Select bits
INTCON = $F0 ' Konfiguration INTERRUPT Disable PORTB pull-ups und PS2-PS0 Prescaler Rate Select bits
asm
loop
clrwdt ; Watchdog-Timer loeschen
btfsc PORTB,B_PS ; if PS = LOW
goto loop2
btfsc R_FLAG,F_PS_RDY ; and PS_RDY not set
goto loop
movf R_OLD,W ; .. the reload old values
movwf R_DATEN ;
bsf R_FLAG,F_PS_RDY ; .. set FLAG PS_RDY
goto loop
loop2
bcf R_FLAG,F_PS_RDY ; if PS = LOW reset PS_RDY
goto loop
endasm
lesen:
asm
read_input
clrf R_DATEN
btfss PORTA,A_X8
bsf R_DATEN,0
btfss PORTA,A_X7
bsf R_DATEN,1
btfss PORTA,A_X6
bsf R_DATEN,2
btfss PORTA,A_X5
bsf R_DATEN,3
btfss PORTA,A_X4
bsf R_DATEN,4
btfss PORTA,A_X3
bsf R_DATEN,5
btfss PORTA,A_X2
bsf R_DATEN,6
btfss PORTA,A_X1
bsf R_DATEN,7
movf R_DATEN,W
movwf R_OLD
endasm
