Greetings all, this forum has been a great source of info, so thanks!
I am doing the speed, miles thing as shown in the following code. This works great until I slow to around 9 mph, then the timer overflows. If I test for an overflow, I can either set the speed to 0 or I can add 524 ms to the time and assume one timer overflow. That now works great down to ~4 mph. Below that, another overflow happens and my time is once again inaccurate. 16f676 running at 4MHz. In the code below, I have the first overflow commented out (PIR1.0) . Any suggestions on keeping track of these overflows? Thanks, Scott
Code:define LCD_DREG PORTC
define LCD_DBIT 0
define LCD_RSREG PORTC
define LCD_RSBIT 5
define LCD_EREG PORTC
Define LCD_EBIT 4
define LCD_BITS 4
define LCD_LINES 2
Define LCD_COMMANDUS 2000
Define LCD_DATAUS 50
Define OSCCAL_1K 1
CMCON = 7 'Port A to digital
ANSEL = 0
TRISA = %00001100
TRISC = %00000000
OPTION_REG = %01000000 'rising edge interrupt
PIE1 = %00000000 'enable tmr1 overflow int w/ bit0
PIR1 = %00000000 'reset per interrupt flags
INTCON = %10010000 'global enable...
T1CON = %00000000 'timer1 reset
eeprom 0,[0,0] 'mile count storage - low byte first
eeprom 2,[0,0] 'pulse count storage
pulses var word 'timer register value 8uS per pulse
pulses = 0
w var word 'miles value
w = 0
x var word 'pulse count value
x = 0
y var word 'mS value
y = 0
z var word 'mph value
z = 0
D var byte
D = 0
Pause 500 'wait for LCD to startup
on interrupt goto myint
intcon = $90
start: Lcdout $fe, 1 'clear LCD
lcdout $fe, $80
lcdout "IntSPEED"
LCDOUT $fe, $C0
LCDOUT "Ver 1.0 "
pause 2000
read 0,w.byte0 'read stored mile value
read 1,w.byte1
read 2,x.byte0 'read stored pulse count
read 3,x.byte1
T1CON = %00110001 'start timer
TMR1L = 0
TMR1H = 0
loop: Lcdout $fe, 1
lcdout $fe, $80
lcdout #y," ",#z
LCDOUT $fe, $C0
lcdout #x," ",#w
for D = 1 to 100
pause 1
next D
Goto loop 'do it forever
Disable
myint: pulses.byte0 = TMR1L 'value of timer to pulses variable
pulses.Byte1 = TMR1H
TMR1L = 0 'start timer over
TMR1H = 0
'.001 = 125 * .000008
y = pulses / 125 'convert X 8uS pulses to mS
'if PIR1.0 = 1 then 'slow speed issues
' y = y + 525 'timer overflow
' PIR1.0 = 0 '~9 mph
' endif
z = 4900 / y 'convert ms to mph
if y = 0 then z = 0 'eliminate 65535 speed at 0mS
if PIR1.0 = 1 then 'timer overflow
z = 0
PIR1.0 = 0
x = x + 1 'increment pulse count
write 2,x.byte0
write 3,x.byte1
if x = 733 then '733 revs per mile at 27.5 dia wheel
w = w + 1 'increment odometer
write 0,w.byte0
write 1,w.byte1
x = 0 'reset pulse counter
intcon.1 = 0
resume
enable
