Run a string of LEDs from the mains
Hi, I would like to run 80 LEDs directly from the mains. Here in the UK the mains is 240V. That gives 3V per LED and they are rated at 3-4V. Would there be any problems with this? Ive been told that i should use a current limiting resistor when running LEDs from 12V. As far as im aware thats only needed if the input voltage is greater than whats required (i still dont completely understand this stuff).
As its AC then there would be a slight flickering on the LEDs. Could i use 4 diodes to make a rectifier? The diodes are only meant for about 50V 1A. Technically they would be in series with the LEDs so it shouldnt matter. Could it cause any problems though?
I thought about adding a capacitor aswell to reduce the flicker as much as possible. I found one thats 470N 250V. Would 470N be enough?
