splitting output from a counter
Hello all, I'm trying to figure out a way to have a 12F683 take a variable frequency square wave in and generate a pulse train out from two pins. The input would never go above 3Khz and the output would look like this:
pin3-pin2-pin2-pin2-pin2-pin3-pin2-pin2-pin2-pin2-pin3
One pulse from pin 3 and then four pulses from pin 2 all depending on the incoming frequency. The code so far doesn't seem to work very well.
@ __CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
DEFINE OSC 8 ' Internal 8MHz
'DEFINE ADC_BITS 8 ' 8-bit resolution
'DEFINE ADC_CLOCK 2 ' Set clock source to Frc/32
'DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
CMCON0 = 7 'Comparators off
ADCON0 = %00000000
ANSEL = %00000000
INTCON = 0 'INTERRUPTS off
OSCCON = %01110000 '8 Mhz
TRISIO = %000100
GPIO = %00000100
OPTION_REG = %00101000
A VAR byte
TMR0= 0 ' clear count
low GPIO.4
low GPIO.5
input GPIO.2
A=0
while TMR0 <= 5
wend
A= A+1
if A = 4 then largepulse
pulsout GPIO.5, 100 '500 uS short pulses pin 2
gosub main
largepulse:
pulsout GPIO.4, 100 '500 uS big pulse pin 3
A=0
Am I way off here or on the right track?
