Variables and port pins
Having assigned a variable name to a port pin, eg:
MyPin VAR PORTB.1
I would like then to be able to use another variable to refer to that pin, eg:
x = MyPin
High x
Is there any way to do this as I have tried many ways but nothing seems to work.
Alternatively, if this would work, I could do what I want this way:
If a = 1 then
p VAR PORTB.1
p VAR PORTB.2
But, when this is compiled, it reports that the variable p in the ELSE section is already an alias implying it is assiging the variable at compile time rather than when the IF statement runs.
Many thanks for any help or suggestions.
Peter
VAR is a COMPILE TIME directive... ie it is acted upon by the compiler when your program is compiled and assembled - it is NOT an instruction or COMMAND that is acted upon during execution (RUN TIME).
Using your own example... if you say...
x=MyPin
...you are transferring the state of MyPin into the variable x (assuming you have previously defined x as a variable).
You can have multiple definitions for any given pin...
x var PortB.1
MyPin var PortB.1
Thereafter you can use any one you want within your program. But once defined, your definitions can't be changed or reassigned 'on-the-run'.
Many thanks, Melanie. All understood.
Peter
