Sony LanC Program
'Testing Sony LanC control of video camera [email protected] (Larry) SCS Saturday August 29, 2009
'Sending commands is LSB first example hex 22, %00100010 you send the far right zero first then the one then three zeros
'and a one then two more zeros. The Lanc port is held in the high state by the camera, Pulling the pin low is a 1
'I used input command to keep the line in its high state at 5vdc, and low to pull the line low for a 1. So again
'using the hex 22 example %00100010, input,low,input,input,input,low,input,input.
@ DEVICE PIC16F84,HS_OSC,WDT_OFF,PWRT_ON,PROTECT_OFF
DEFINE OSC 10
command_bit var bit
syncbit var byte
syncbyte var word
counter var byte
value var byte
Bits var byte
Goto start
Sync_byte: 'Sync_byte looks for the inter_frame gap 5.4mS to 7mS at the end of every
syncbyte = 0 'frame tranmissions and just before the start of the next frame
while syncbyte < 700
pulsin portb.1, 1, syncbyte
wend
Sync_bit: 'Sync_Bit looks for the start_bit of each frame this is used
syncbit = 0 'in sending the second byte of a command
while syncbit < 9
pulsin portb.1, 0, syncbit
wend
Command_byte: 'tell camera that a command is to follow normal commands
gosub sync_byte
pauseus 80 'pause for camera's start bit to finish
input portb.2 'first byte to send (LSB 1ST)Hex 18 %0001,1000
pauseus 312
low portb.2
pauseus 208
input portb.2
pauseus 312
input portb.2 'Stop bits set high
Command_byte2: 'tell camera that a command is to follow special commands
gosub sync_byte
input portb.2 'first byte to send (LSB 1ST)Hex 28 %0010,1000
pauseus 312
low portb.2
pauseus 104
input portb.2
pauseus 104
low portb.2
pauseus 104
Start:
counter = 0
gosub Power_off
pause 10000
counter = 0
gosub Wakeup
gosub Power_on
pause 10000
counter = 0
gosub Record_on
pause 20000
counter = 0
gosub Record_on
pause 10000
goto Start
Power_off:
gosub Command_byte
gosub sync_bit
input portb.2 'Power off command #5E (LSB 1ST) %0101,1110
pauseus 104
low portb.2
pauseus 416
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 104
counter = counter +1
if counter = 3 then Return
goto Power_off
Power_on:
gosub Command_byte
gosub Sync_bit
input portb.2 'Turn camera on from sleep mode
pauseus 208 'Power on Command 5C (LSB 1ST) %0101,1100
low portb.2
pauseus 312
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 208
if counter = 300 then Return
goto Power_on
Record_on:
gosub Command_byte
gosub Sync_bit
low portb.2 'Start Recording
pauseus 208 'Power on Command 33 (LSB 1ST) %0011,0011
input portb.2
pauseus 208
low portb.2
pauseus 208
input portb.2
pauseus 208
if counter = 5 then Return
goto Record_on
Record_off:
gosub Command_byte2
gosub Sync_bit
low portb.2
pauseus 104
input portb.2 'Start Recording
pauseus 208 'Power on Command 29 (LSB 1ST) %0010,1001
low portb.2
pauseus 104
input portb.2
pauseus 104
low portb.2
input portb.2
pauseus 208
goto Record_off
Wakeup:
low portb.2 'This wakes camera up for short period to accept commands
input portb.2
Sony LanC
This is updated code!! it uses two pins of a 16f84 b1 and b2. b1 is the sync pin which keeps the program synced with the camera using the lanc line. you need a 2k resistor from the lanc line to b1 and a 20k resistor from ground to b1, portb2 needs a 2k resistor to the lanc line. the code as written will take a 10 second movie every 15 minutes.
'Testing Sony LanC control of video camera [email protected] SCS Saturday August 29, 2009
DEFINE OSC 10
command_bit var bit
syncbit var byte
syncbyte var word
counter var byte
value var byte
Bits var byte
Time var byte
pause 5000
Goto start
wend
while syncbit < 9
wend
gosub sync_byte
pauseus 312
low portb.2
pauseus 208
input portb.2
pauseus 312
Start:
counter = 0
gosub Power_off
pause 2000
gosub DelayTime
counter = 0
gosub Wakeup
gosub Power_on
counter = 0
gosub Record_on
pause 10000
counter = 0
gosub Record_on
goto Start
Power_off:
gosub Command_byte
gosub sync_bit
pauseus 104
low portb.2
pauseus 416
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 104
counter = counter + 1
goto Power_off
Power_on:
gosub Command_byte
gosub Sync_bit
low portb.2
pauseus 312
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 208
goto Power_on
Record_on:
gosub Command_byte
gosub Sync_bit
pauseus 208 'Record On 33 (LSB 1ST) %0011,0011
input portb.2
pauseus 208
low portb.2
pauseus 208
input portb.2
pauseus 208
goto Record_on
DelayTime: 'Sets delay time in minutes
For Time = 0 to 14 'How many one minute delays
pause 60000 'One minute delay time
Next Time
Wakeup:
input portb.2
' pause 100
Sony Lanc
This updated has been tested using 4mhz and 10mhz and the timing was changed from 80mS to 60mS. It has been tested without pulldown resistors
although not looked at with a scope. Three resistors is all thats needed to interface with a camera two each 2k resistors from lanc line to pins portb.1 and portb.2 with a 10k to 20k pulldown from portb.1 to ground. program will wait 5 minutes and take a 10 second video turn off for 5 minutes wake and take a 10 second video ON and ON.
Turn camera on, then power pic after 5 seconds pic will power down camera and in 5 minutes will wake an make a video, you get the idea.
DEFINE OSC 10
command_bit var bit
syncbit var byte
syncbyte var word
counter var byte
value var byte
Bits var byte
Time var byte
pause 5000
Goto start
wend
while syncbit < 9
wend
gosub sync_byte
pauseus 60 'pause for camera's start bit to finish
pauseus 312
low portb.2
pauseus 208
input portb.2
pauseus 312
Start:
counter = 0
gosub Power_off
pause 2000
gosub DelayTime
counter = 0
gosub Wakeup
gosub Power_on
counter = 0
gosub Record_on
pause 10000
counter = 0
gosub Record_on
goto Start
Power_off:
gosub Command_byte
gosub sync_bit
pauseus 104
low portb.2
pauseus 416
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 104
goto Power_off
Power_on:
gosub Command_byte
gosub Sync_bit
low portb.2
pauseus 312
input portb.2
pauseus 104
low portb.2
pauseus 104
input portb.2
pauseus 208
goto Power_on
Record_on:
gosub Command_byte
gosub Sync_bit
input portb.2
pauseus 208
low portb.2
pauseus 208
input portb.2
pauseus 208
goto Record_on
For Time = 0 to 4 'How many one minute delays
Next Time
Wakeup:
input portb.2
' pause 100
