lcd 4 line
hi anybody could help me how to display a 4 line character lcd.
sample code
pause 1
lcdout $fe,1," Hello world", $fe,c0," hello again" ,fe,94,"welcome" fe,d4,"thank you"
lcd 4 line
sample code
pause 1
Hello Jojo,
Chances are, you have two enable lines... one for the top 2 lines and one for the bottom two lines..
Do a search on LCD in this forum... here is a example of a search
http://www.picbasic.co.uk/forum/show...ghlight=LCD%2A
Dwayne
OR you forget to include
DEFINE LCD_LINES 4
Also try to increase you start up delay to 1 second.
is your LCD display something??? at least on the 2 first line.
I agree with DWAYNE, your LCD probably have 2 enable line if it's a 4X40 one.
hi thank for help
i am using 4x20 lcd
It will be hard for us if you don't provide any info of your hardware connection, crystal speed and the PIC you're using.
Let's assume you use the same connection in the PBP manual.
Usually 4X20 LCD don't have 2 enable line. BUT some will need to place the 4 unused data bit to ground
Try with this snippet and let us know.
this one should work.Code:
DEFINE OSC 4 ' Using 4 MHZ crystal
DEFINE LCD_LINES 4 ' Using a 4 lines LCD
pause 1000 ' wait LCD start-up delay
' P.S.: it can be higher or lower depending of
' the model you're using
Start:
lcdout $fe, 1,"Line 1",_
$fe,$c0,"Line 2",_
$fe,$94,"Line 3",_
$fe,$d4,"Line 4"
Here:
goto here
