Some help needed (newb content)
Hello,
Ok, I've been programming in Ass for a while, and now have seen the light.
Simple prog to flash an led if a button is pressed.
Code follow:
@ DEVICE pic16F819
@ DEVICE INTRC_OSC_NOCLKOUT
@ DEVICE CPD_OFF
Define OSC 8 'Osciallator 8Mhz
OSCCON=112 'INT OSC 8 MHZ
ADCON0 = 0
CCP1CON = %00000000 'Turn comparators off
Trisa=%00000001 'Sets PortA RA0 and RA1 as ip rest as output.
CoolHeat Var PORTA.0 'Switch IP High=flash
RL1 Var PORTA.1 'Relay output
Start:
If CoolHeat=0 THen 'button not pressed
HIGH RL1
If Coolheat=1 Then 'button pressed flashes LED
high rl1
Low RL1
Pause 500
high rl1
Low RL1
Pause 500
Endif
goto Start
The switch is pulled up via 4k7 to Vcc. LED has 330r in series.
When I power up the led is on as it should be, switch is open.
When I pull RA.0 high the led *should* flash but does not.
Any ideas?
Many thanks.
Need to also set RA1 as input
Woogle
Your Trisa statement only sets RA0 as in input. Your comment says you want to also set RA1 as input. Therefore you need TRISA = %00000011 .
