PIC keeps resetting when executing subroutine
All,
I am having problems with the below code when the subroutine warning is executed. PortA.0 is pulled high with a 1k. When the bin is full the limit switch pulls PortA.0 low. The buzzer and light will blink 2 times then the PIC will reset. I have used 2 different PIC's. - F84A and F819. Both PIC's do the same thing. 5V is solid and I have plenty of decoupling and bulk capacitance sprinkled throught the circuit. For the warning lamp and buzzer driver I use 1k to the base of a 2N4401 transistor's to drive the light and buzzer. I tried Tris statements and ADCON setup with the F819 with no help. I have tried HC and XT osc drive settings. Both parts are rated for 20MHz operation. I set power up timer to off and brownout off. All I want is the buzzer and light wo toggle 5 times then if the switch is still low at PORTA.0 then just have the binlight on until PORTA.0 hoes high. I'm about to smash this with a hammer soon as something this simple should not cause this much trouble.
Any help here is appreciated.
'* Name : Combine.BAS *
'* Notice : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 8/15/09 *
'* Version : 1.0 *
'* Notes : *
define OSC 20
'ADCON0 = %11000001
'ADCON1 = %10001110
'trisa = %00001110
'trisb = %11110111
binlight var porta.1
buzzer var portb.2
backup var porta.2
alarm var byte
define LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 1
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
low buzzer
low binlight
low backup
PAUSE 500
alarm = 0
high buzzer
high binlight
high backup
toggle buzzer
toggle binlight
toggle backup
LCDOUT $FE,1
LCDOUT $FE,$80, "TattleTale X"
LCDOUT $FE,$C0, " Monitor"
pause 5000
LCDOUT $FE,1
monitor:
LCDOUT $FE,$80, " No Alarms"
LCDOUT $FE,$C0, " "
if alarm = 1 then
goto light
if PORTA.0 = 0 thEN
alarm = 1
GOsub warning
GOto monitor
warning:
LCDOUT $FE,1
LCDOUT $FE,$80, " BIN FULL!!!"
LCDOUT $FE,$C0, " "
high binlight
high buzzer
pause 200
toggle binlight
toggle buzzer
pause 200
toggle binlight
toggle buzzer
pause 200
toggle binlight
toggle buzzer
'pause 200
'high binlight
'high buzzer
'pause 200
'low buzzer
'low binlight
light:
if PORTA.0 = 0 then
high binlight
alarm = 0
GOTO monitor
