I switched over to MPASM several months ago when I started using an 18F4520. I'm going back to some of my other code that needs an update and am having trouble with a 16F631. I have commented out the config lines in the inc file. I get "Error[113] c:\pbp\pbppic14.lib 5985 : Symbol not previously defined (EEPGD)"
After stripping down the code I have isolated the error to anytime I use a read or write statement. If I switch back to PM all is well.
Any ideas? I would rather not have to always switch back and forth depending on which chip I'm using. I uninstalled and removed MPASM and installed the newest version already.Code:define osc 8
Clear
'@ device pic16F631, INTOSCIO, wdt_on, pwrt_on, MCLR_OFF, protect_on, IESO_OFF
@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _IESO_ON
OSCCON = %01110101 'set internal osc on to 8 mhz
Prev_Baud var byte
ANSEL = 0 'set port to digital
OPTION_REG.7 = 0 'enable pull ups on A and B
read 0, Prev_Baud
if Prev_Baud > 4 then 'don't allow anything over 19200, default to 9600
write 0, 3
Pause 1000
David
