hi everyone...
I've writen a PB program to controll a pulse motor...
It compiles without any errors or warnings...
It runs in the oshon soft pic simulation IDE with out a problem
As soon as i try to run it in a PIC random ports become high but don't change...
I have a test program that runs fine and that uses the same serout2 command and it sends data to my PC without a problem...
I'm guessing i missed something that i should have setup... can someone take a look and tell me what i missed?
I've got no idea on where to begin to diagnose this type of problem...
Thank youCode:include "bs1defs.bas"
Define CONF_WORD = 0x3F3A
Define OSC 20 ' Set clock speed
Define ADC_SAMPLEUS 10 ' Set sampling time in uS
ADCON0.7 = 0 ' ADC clock set to Fosc/2
ADCON0.6 = 0 ' ADC clock set to Fosc/2
ADCON1.6 = 0 ' ADC clock set to Fosc/2
INTCON = 0 ' Disable all interupts
'DEFINE SER2_BITS 8 ' Ser2 number of data bits
'RCSTA = %10010000 ' Enable serial port and continuous receive
'TXSTA = %00100100 ' Enable transmit and asynchronous mode with BRGH 1
'SPBRG = 20 ' Set baud rate to 57600 with 20mhz clock (BRGH = 1)
ADT1 var word ' Create ADT1 to store curent ad conversion for AD channel 0
ADT1MAX var word ' Create ADT1MAX to store curent ADC0 max val
ADT1MAX = 0
ADT1VAL var word
ADT1VAL = 0
ADV1 var word
VOLT1H var word
VOLT1L var word
C1N var bit
C1N = 0
C1S var bit
C1S = 0
PCOUNTER var byte
PCOUNTER = 0
PTICK var bit
PTICK = 0
RPM var word
RPM = 0
TMR1_VAL var word
TMR1_VAL = 0
TRISE = 255 ' Set PortE to all inputs
TRISD = 0 ' Set PortD to all outputs
TRISC = 0 ' Set PortC to all outputs
TRISB = 0 ' Set PortB to all outputs
TRISA = 255 ' Set PORTA to all input
ADCON1 = 0 ' PORTA is analog
PIE1.0 = 0 ' Disable TMR1 interupt (double check)
T1CON.5 = 1 ' Setup TMR1 timings
T1CON.4 = 1
T1CON.3 = 1
T1CON.1 = 0
T1CON.0 = 1
gosub getadc
gosub control
gosub backemfreuse
gosub rpmcounter
gosub adcvonvert
gosub telemetry
getadc:
ADCIN 0, ADT1
adcvonvert:
ADT1 = ADT1 / 64
VOLT1H = ((48 * ADT1) / 10000)
VOLT1L = ((48 * ADT1) - (((48 * ADT1) / 10000) * 10000)) / 100
rpmcounter:
if PCOUNTER = 4 then
T1CON.0 = 0 ' Pause TMR1
TMR1_VAL.lowbyte = TMR1L ' Load TMR1 Low end byte
TMR1_VAL.Highbyte = TMR1H ' Load TMR1 High end byte
RPM = 60000 / ((TMR1_VAL * 16)/10000)
PCOUNTER = 0
TMR1L = 0
TMR1H = 0
T1CON.0 = 1
telemetry:
'HSEROUT ["V1:",DEC5 VOLT1H,".",DEC5 VOLT1L," RPM:", DEC5 RPM,10]
SEROUT2 PORTD.0,16468,["V1:",DEC VOLT1H,".",DEC VOLT1L," RPM:",DEC RPM,10]
control:
'IF ADT1 > 200 and ADT2 > 200 then
' LOW PORTB.0
' LOW PORTB.1
' C1N = 0
' C1S = 0
' return
' ENDIF
IF ADT1 > 200 then
high PORTB.0
LOW PORTD.7
C1N = 1
IF PTICK = 0 then
PCOUNTER = PCOUNTER + 1
PTICK = 1
IF ADT1 < 200 then
LOW PORTB.0
C1N = 0
IF PTICK = 1 then
PTICK = 0
backemfreuse:
if C1N = 0 then 'and C1S = 0
High PORTD.7
Else
LOW PORTD.7
