Beginner having trouble with interrupt..
Hello everyone,
I'm trying to make a simple program that will blink a LED on PortB.2. While waits for an incoming character to PortC.7(with max232). My trouble I think is with the command serin PortC.7, T2400, RX and my PortB.2 doesnt blink. I appreciate any help/guide to understand how I can make this work. :)
CLEAR
include "modedefs.bas" 'include serout defines
DEFINE OSC 20
OPTION_REG=%10000101
;Bit 7=1 disable pull ups on PORTB
;Bit 5=0 selects timer mode
;Bit 2=1 }
;Bit 1=0 } sets Timer0 pre-scaler to 64
;Bit 0=1 }
INTCON=%10100000 ;Bit 7=1 Enables all unmasked interrupts
;Bit 5=1 Enables Timer0 overflow interrupt
;Bit 2 flag will be set on interrupt and has to be cleared
;in the interrupt routine. It is set clear to start with.
RX var byte ; holds incoming character
symbol led1=PORTB.0
symbol led2=PORTB.1
i var byte ;counter
Cnt var byte
TRISB = %11110000 ;sets the 3 output pins in the B port
PORTB = %00000000 ;sets all pins low in the B port
TRISC = %10000000 ;Set portC.7 for serial input
ON INTERRUPT GOTO INTERUPTROUTINE
MAINLOOP:
High PORTB.2
For i = 0 to 200
Pause 1
Next i
Low PORTB.2
For i = 0 to 200
Pause 1
Next i
IF Cnt=49 then
led1=1-led1
Cnt=0
if Cnt=50 then
led2=1-led2
Cnt=0
GOTO MAINLOOP ;end of loop
DISABLE
INTERUPTROUTINE:
serin PortC.7, T2400, RX 'Receive menu
Cnt = Rx
ENDINTERRUPT: ;
INTCON.2 = 0 ;clears the interrupt flag.
RESUME ;resume the main program
ENABLE ;DISABLE and ENABLE must bracket the int routine
mbox
