I have a very simple question. Can I create an alias for two input pins say:
Switch.0 VAR PortA.0
Switch.1 VAR PortA.1
And then use Switch with Select Case to perform functions based on the setting of the two switchs.
When I try to compile the above code, I get a syntax error.
Thanks...Chris
