HSerin problems on power up
This is a problem I've encountered for years on several different chips and have always just kind of ignored it. I have a problem using the Hserin command on initial power up. Below is a stripped down version of my code. Basically I power up the chip and wait a little while then send a burst of data. that data is basically ignored, I send a second burst and it is processed as is every burst after. if I hit the reset button every burst is processed, but if I turn off the power and wait a few seconds before powering back up the problem comes back for the first burst of data. I've checked the overflow and framing error bits, and see no problem. There are only a few registers I can even think to look at, but nothing is popping out at me. it seems like it would have to be something obvious.
INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
Clear
DEFINE OSC 40 ' Set Xtal Frequency
DEFINE HSER_CLROERR 1 'will automatically clear overflow errors
stream VAR BYTE[80] 'the last stream in
view_stream var byte[104] 'outsream converted to patterns
a VAR BYTE 'loop counter variable
b VAR BYTE
x VAR BYTE 'loop counter variable
B0 VAR BYTE
B1 VAR BYTE
B2 VAR BYTE
B3 VAR BYTE
B4 VAR BYTE
B5 var byte
pattern var byte
new_stream var bit
red_LED VAR PORTC.4 'red led
CSALL CON %00000000 'Chip Select for all chips
CSOFF CON %00001111 'chip select for no chips
CSB0 VAR PORTB.0
CSB1 VAR PORTB.1
CSB2 VAR PORTB.2
CSB3 VAR PORTB.3
TRISA = %11101100
TRISB = %11110000 'inputs for upper half switches outputs for lower CS
TRISC = %11001111 '0-3 for switches, 4-5 for LEDs, 6-7 for serial data
TRISD = 0
TRISE = 0
PORTB = CSOFF
PORTE.0 = 1
PORTE.1 = 1
PORTE.2 = 0
ADCON1 = %00001111
;****************Using Darrel Taylor Interrupts****************************
;----[High Priority Interrupts]--------------------------------------------
INT_Handler RX_INT, _GetData, PBP, no
INT_CREATE ;Creates the High Priority interrupt processor
red_LED = 0 'turn on red LED
Pause 1000
top:
TXSTA = $20 ' Enable transmit, BRGH = 0
SPBRG = 34 ' 1200 Baud @ 0.0%
SPBRGH = 8
BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
RCSTA = $90 ' Enable serial port & continuous receive
GoSub send_data
countdown:
'count from 9 to 0
For x = 9 TO 0 STEP - 1
For a = 0 TO 79
stream[a] = x + "0"
Next a
GoSub send_data
Pause 150
Next x
end_countdown:
'check buttons
@ INT_ENABLE RX_INT ; enable RX_INT interrupts
RCSTA = $80 'clear CREN
RCSTA = $90 'Enable receive
mainloop:
if new_stream = 1 then
RCSTA.4 = 0
RCSTA.4 = 1 'clear over run error
new_stream = 0
GoSub send_data
GoTo mainloop
send_data:
'this sub will send bit patterns via psp (non interrupt driven) to another chip
'---[USART RX - interrupt handler]-----------------------[High Priority]---
GetData:
hserin 1000,No232,[str stream\80\10]
red_LED = red_LED +1 'heartbeat
new_stream = 1
No232:
@ INT_RETURN
David
