Has anyone implemented an OSD using a PIC and MAX 7456 IC? Would love to see a schematic and code example.
Have a look at their Evaluation Kit
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5569/t/al
They provide the whole schematic (which look really like the one in the DataSheet, what a coincidence). From there, it's just a matter of having fun to remove some not needed stuff, and connect it to your favourite PIC micro.
They also have few app note, tutorials and software. Download everything, sit back and enjoy some reading :D
You'll need to use some kind of SPI communication, SHIFTOUT may work, but for some reason, I feel it will be a bit too slow... worth a try, that's for sure.
Choose a PIC with decent memory size and with MSSP port, and you're ready to discover the joys of head-banging and software/hardware design from almost ground zero.
Here's few code example in Proton PDS. Should be easy enough to convert.
http://www.picbasic.org/forum/showthread.php?t=10723&
That's a neat and cute IC, a little pricey though...
Was hoping to not have to spend 100 bucks on an eval kit. Anyone have experience actually implementing this?
I never said that, I gave you links to it, so obviously you haven't go there yet.
Hello,
stop on by www.thesiliconhorizon.com
we have 2 boards that use the max7456.
one is powered by a 40 mips dsPIC.
the other is a dev board that just has the max 7456 and you can hook it to whatever... (this is the cheaper solution.)
stop on by.
code is included with the techFX Motion OSD board.
it also uses a GPS, optional accelo and an optional IMU.
lots of goodies on it.
thnx
oh yah we also have a video of its output, however the output is whiter now than the video shows...
but itll give you an idea of what you can do with it.
we didnt use a custom character set with the max 7456,
but we did implements a directional heading that scrolls and it works great.
code is included with purchase.
