helllo
here is my problem, i got the posttemp variable declared like this
now i want to change the value of the variable like thisCode:posttemp var byte
and then compare posttemp like thisCode:if menu = 2 then
posttemp=$0AF0
LCDOUT $FE,1, "Max temperatura:"
lcdout $FE,$c0,128, "28.00 C"
pause 2000
if menu = 3 then
posttemp=$0BB8
lcdout $FE,$c0,128, "30.00 C"
pause 2000
but this isn't working, program is compiled without erors, everythig is working fine, but my program gosub to s3 ever time, no matter if the condition is true!Code:if temp >= posttemp then gosub s3
and if i put it this way
then everything is working just fine but i want to change value $0AF0 like in above not working examplelCode:if temp >= $0AF0 then gosub s3
thx in advance
www.mtskola.com
