If a max232 chip is only used to convert rs232 to ttl are only 4 pins used? I am sending serial from a pc to a pic with no tx from the pic. The datasheet says that the external capacitors are used for the charge pump to get 5v to rs232 levels. If im not converting that direction do I need these? Should just be Vcc, Vss, R1in and R1out right?
Jason
