I checked the FAQ could not find an answer to this one. Does a Picstart work with a USB to Serial Convertor? My laptop does not have a Serial port and I need to do some work in the field. Is there a USB Picstart? Which convertor worked for you?
USB to serial adapter are suppose to do the same job as a regular serial port. There's no USB PICSTART. so i figure it's really suppose to work as well.
usb adapter available :
melabs http://www.melabs.com/products/accessry.htm.
SfCable http://www.sfcable.com/Merchant2/mer...ROD/72/UB30-40
Sewell Direct http://sewelldirect.com/USBtoSerial....ch_type=search
A search on Google can give you also many other place.
I use an IOGear USB/Serial converter on an HP ze5300 laptop. It works with the PicStart Plus & MeLabs serial programmers.
