Hello,
I seem to have hit a issue that I cannot pinpoint. I was not there when it happened and have not looked at it yet but I have been told that a board that mounts on top of a series string of batteries. The pic is not starting up at this time however the regulator is putting out the requisite 3.3 volts. Could it have something to do with having voltage dividers feeding the a/d channels on the pic before the pic is up and running? Any thoughts as to what may be happening/causing problems here?
The board worked prior to it being attached to the battery pack and then once attached it worked and operated as designed. The pack and board were taken apart the other day and when reassembled the pic did not come back.
Thanks again in advanced.
