Help Pbasic to PBP
Please help me to translate this code to PBP. I need this for my robotic project.I am using 16F877a .
' -----[ Title ]-----------------------------------------------------------
' File...... PARROT.BS2
' Purpose... ISD25xxx Controller
' Author.... Jon Williams
' E-mail.... [email protected]
' Started... 03 APR 1999
' Updated... 29 JUL 2000
' -----[ Program Description ]---------------------------------------------
' This program, based on an original by Mike Politoski, controls anISD25xxx
' series ChipCorder(r) IC. This program allows the user to record a
' message (length determined by the chip) and play it back several times
' to train a parrot or other talking bird.
' Note: The ISD25xxx is configured for Mode 6, push-button mode.
' Modes:
' - Record: Press and hold record button
' - Play: Press play button
' - Training: Press start button
' -----[ I/O Definitions ]-------------------------------------------------
LEDr_ CON 6 ' recording LED
LEDp_ CON 7 ' playback LED
LEDt_ CON 8 ' training LED
PR CON 9 ' ISD Play/Record_
PD CON 10 ' ISD Power Down
CE_ CON 11 ' ISD Chip Enable
BtnRec VAR In12 ' Record control button
BtnPlay VAR In13 ' Play control button
BtnGo VAR In14 ' Start control button
RecRun VAR In15 ' recording/running out from ISD
bPort VAR InD ' buttons port
' -----[ Constants ]-------------------------------------------------------
On CON 0 ' active low
Off CON 1
Yes CON 1 ' active high
No CON 0
' -----[ Variables ]-------------------------------------------------------
btns VAR Nib ' debounced inputs
state VAR Byte ' button input state
delay VAR Word ' delay before training
x VAR Byte ' loop counter
y VAR Word ' loop counter
plays VAR Word ' plays counter
' -----[ Initialization ]--------------------------------------------------
Init:
HIGH PD ' reset ISD address
HIGH CE_
HIGH PR ' default to Play mode
HIGH LEDr_ ' record LED off
HIGH LEDp_ ' play LED off
HIGH LEDt_ ' train LED off
PAUSE 30 ' allow device to reset
LOW PD ' bring out of reset
' -----[ Main Code ]-------------------------------------------------------
GOSUB GetBtn
IF btns > %000 THEN Main ' wait for release
Scan:
GOSUB GetBtn
LOOKDOWN btns,[%000, %001, %010, %100],state
BRANCH state,[Scan, _Rec, _Play, _Train]
GOTO Scan
_Rec:
PAUSE 250 ' time to get ready
LOW PR ' record mode
GOSUB Blip ' initiate recording
LOW LEDr_ ' record LED on
RLoop:
GOSUB GetBtn
IF btns = %001 THEN RLoop ' record until release
HIGH PD ' reset device
GOTO Init
_Play:
PAUSE 500 ' time to release play
HIGH PR ' playback mode
GOSUB Blip ' initiate playback
LOW LEDp_ ' play LED on
PLoop:
GOSUB GetBtn
IF btns > %000 THEN Init ' abort if any button pressed
IF RecRun = Yes THEN PLoop ' check until message done
GOTO Init
_Train:
PAUSE 500 ' time to release start button
FOR delay = 1 to 280 ' 5 minute delay
LOW LEDt_ ' train LED on
FOR y = 1 TO 9 ' ~1/2 second delay
GOSUB GetBtn ' - check inputs
IF btns > %000 THEN Init ' abort if button pressed
NEXT
NEXT
NEXT ' delay
FOR plays = 1 TO 100 ' play message 100 times
HIGH PR ' play mode
SLoop:
GOSUB GetBtn
IF RecRun = Yes THEN SLoop ' wait until finished playing
HIGH PD ' reset the ISD
PAUSE 25
LOW PD ' out of reset
FOR y = 1 TO 500 ' 30 second delay between plays
GOSUB GetBtn ' scan buttons
IF btns > 0 THEN Init ' abort if button pressed
NEXT
NEXT
GOTO Init ' reset and start over
' -----[ Subroutines ]-----------------------------------------------------
Blip:
LOW CE_ ' initiate playback or record
PAUSE 25
HIGH CE_
' scan and debounce button inputs
' - inputs must stay low for 50 ms
' - any debounced button returns high bit in "btns"
GetBtn:
btns = %0111 ' scan record, play and wait
FOR x = 1 TO 5
btns = btns & ~bPort ' check current state
PAUSE 10
NEXT
ON and Off are reserved words so change them, I added another letter to their ends, no NIB var type, so change to BYTE variable, Now In12,13 14 . . . must be aliases for ports, your choice, I tried portB pins and it all compiles.
Thanks Joe S.
I'll give a try and see the outcome.
