xport code, have example, confused though
Hi everyone. so I'm excited to get the xport direct up and running and I see some of you here have used it.
I got the following code from : http://www.tigoe.net/pcomp/code/cate...basic%20Pro/35
but I'm unsure of how to use it. (can a 16f628 run the xport? it can right? it's just serial communication...)
my understanding thus far is
1. I need to use a terminal such as windows hyperterminal to set it up (can this instead be done via pbp?
2. hook up and run code.
I'm unsure of an exact hook up but I'm sure the manual will tell me, but I've tried to first compile the example code and get LOTS of errors...
not sure why, are there includes or other things I should be doing to get this code to compile? I'm using microcode studio and pbp 2.45
Thanks for any and all help!
The relevant Xport settings for this application are as follows:
*** Channel 1
Baudrate 9600, I/F Mode 4C, Flow 00
Port 10001
Remote IP Adr: --- none ---, Port 00000
Connect Mode : D4
Disconn Mode : 00
Flush Mode : 00
*** Expert
TCP Keepalive : 45s
ARP cache timeout: 600s
High CPU performance: disabled
Monitor Mode @ bootup : enabled
HTTP Port Number : 80
SMTP Port Number : 25
The code:
' Xport_to_SQL
' Microcontroller is connected to a Lantronix Xport
' serial-to-ethernet device. This program connects
' to a HTTP server through the Xport, makes a HTTP GET
' request for a PHP script, and sends the value
' of an analog sensor through as a part of the
' GET request.
' Xport communicates at 9600-8-n-1 non-inverted (true) serial.
' By Tom Igoe, 31 oct 2005
' updated 25 Oct. 2005
' Define ADCIN parameters
DEFINE ADC_BITS 10 ' Set number of bits in result
DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
' pins to define serial RZX and TX
tx var portc.6
rx var portc.7
' pins with LEDs to indicate whether we're connecting
' or sending an HTTP request:
httpPin var portb.7
TCPPin var portb.6
output TCPPin
output httpPin
' constant to set the baud rate:
inv9600 con 16468
' for non-inverted connections (PIC to Xport direct):
true9600 con 84
' define variables:
adcVar var word
inByte var byte
connected var bit
ADCON1 = %10000010 ' Set PORTA analog and right justify result
connected = 0
' pause to let Xport boot up:
pause 2000
' if you're connected to the server, then
' make a HTTP call. If not, then connect
' to the server:
if connected = 1 then
' read sensors, convert to bytes:
adcin 0, adcVar
' send HTTP GET request for php script:
gosub http_request
' attempt to connect to the server:
gosub xport_connect
tcpPin = connected
' pause so we're not overwhelming the server:
pause 3000
xport_connect:
' turn off LED to indicate HTTP GET is in progress:
'low tcpPin
' wait for a "C" byte to come back:
while inByte <> 67
serout2 tx, true9600, ["C128.122.253.189/80", 10]
serin2 rx, true9600, [inByte]
wend
' turn on TCP pin to indicate that we connected:
'high TCPPin
connected = 1
http_request:
' light LED to indicate HTTP GET request in progress:
high httpPin
SEROUT2 TX, true9600, ["GET /~tqi6023/sql_datalog.php?action=insert&"]
serout2 tx, true9600, ["sensorValue=", DEC adcVar]
serout2 tx, true9600, [" HTTP/1.1", 10]
serout2 tx, true9600, ["HOST: itp.nyu.edu", 10, 10]
' wait for bytes from server:
' php script sends a 0 to end transmission:
while inByte <> 0
wend
' now we're disconnected:
connected = 0
' turn off LED, since GET request is complete:
low httpPin
