:confused:Is there a way to clear data in an array with one instruction? I get tired of spending code space and time on creating a loop to clear the array cells one at a time.
John P
John P
How many different array you have?
Currently in my program I am creating the first array of only 8 bytes (x255), but that will expand depending on ease of operation and speed. I'd like to be able to clear the the whole 8 byte array with one command.
I thought that where the array
DPA var byte [8]
was used that I'd be able to clear the whole array by using
DPA = 0
but that doesn't work.
John P
Virginia Beach, Virginia USA
Doesn't the CLEAR command (manual section 5.8) work for you?
That will ZAP everything... otherwise it's a FOR...NEXT loop if you want to be pickky.
