i have a pic16f88 & xbee on the same breadboard. the pic should run at in input V between 2.0v to 5.5v.
on the breadboard i have a 7805 for the 5v to the pic and a LD3.3 regulator for the xbee.
however, having two voltage regulators is causing a problem when the xbee gnd is on the same rail as the 5v. that issue is probably evident to an EE, which I am not.
Yet, I can't get the pic16f88 to function with 3.3v. At this point I was hoping to have only one voltage regulator and be able to power the pic & xbee.
is there a programmatic setting i'm not using or should be using to get this pic to run with 3.3v ?
