Hi -
How do you know when to use a pullup or a pulldown resistor?
Know when to use what resistor and then what value is not straight forward to me and trying to figure out a simple way to remember to know which to use.
Thanks -
Hi -
Thanks -
If there is a "memory save" button in the system, then I use pull down resistors instead of pull ups. => Button press pulls up.
Reason: If power is removed, then there is a possibility that pin goes down before PIC goes off. The program then acts as if the button was pressed.
ok
Code:If PortA.1 = 1 THEN ' if logic high = true use pulldown to
'make untrue
Do something here !
else ' false this is where the pulldown does it's work.
Code:If PortA.1 = 0 THEN ' If logic low is true use a pullup to
' make false
Do something here !Light an LED . . .
else ' False, again this is where pullup does it's job
Your code here . . . Say, turn off the LED
Thanks - That's what I was thinking you were saying before but wanted to be sure. Greatly appreciate it.
Keith
