Hello everyone,
I am pretty new with Pic Programming . I have to measure the time elapsed between V0-V voltages. I am planning to use a POT as an input and display the time on 2x16 display. I am planning to use 16 F877 .
Any ideas?
Berkay
Hello everyone,
Any ideas?
Berkay
What are the minimum and maximum times you will be needing to measure?
Will you be needing anything else going on at the same time?
Maybe something like
I know, not real code But an idea for you to try.Code:for X = 1 to 255
pause 10
t = t + 1
do whatever, pot
if whatever = thisorthat then tCalc
next x
tCalc:
display t
So if "t" equals 100 , that would mean about a second has passed.
This is for my master thesis project.
My time range is between 300 - 700 microseconds . Depending on the elapsed time value i will control the valves.
Thanks for your help
how can i start the timer for example when the analog input from the pot is 3 V and stop the timer when it is 5 V ?
thanks
You may want to consider using ADCIN in place of POT.Code:loop:
If pot value => 3V then time
goto loop
time:
for X = 1 to 255
pauseus 10
t = t + 1
do whatever, pot
if pot value = 5V then tCalc
next x
tCalc:
display t
goto time
Notice I changed the example to PAUSEUS.
And someplace around here there is a discussion about code execution time, or just test it to adjust the PAUSEUS.
Thanks for your idea,
One more question. How am i gonna define the voltage. I have added a loop like but it didnt work. What can be the problem ?
ADC_READ:
ADCIN 0, ADCINFO
D=ADCINFO*100/51
timeloop:
if D>3 then
T1CON.0=1
if D>=4 then
T1CON.0=0
goto timeloop
First off the ADC needs setup, here is an example.
http://www.microengineeringlabs.com/...pbp/adcin8.bas
Voltage...
Lets say you are using an 8 bit ADC. Voltage reference is VDD and the PIC is running at 5 volts.
There are 256 steps, 0 to 255.
The ADC value of 255 will represent full scale and be 5 volts.
The ADC value of 127 will represent 2.5 volts.
Looking for 3 volts? The ADC vale would be 153.
Want more accuracy? The 10 bit ADC has 1024 steps.
Your loop. After the set up.
That is the basics.Code:loop:
ADCIN 0, adval ' Read channel 0 to adval
IF adval <= 153 then gosub Xlabel '3 volt and less trigger
IF adval = 255 then gosub Zlabel '5 volt trigger
Pause 100 ' Wait .1 second
Goto loop ' Do it forever
Xlabel:
'Do something
Zlabel:
'Do someting
thanks alot
another newbie question
can i use tmrcon istead of for loop
such as;
CalcTime var word
Define LCD_DREG PORTC
Define LCD_DBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 0
Define LCD_EREG PORTB
Define LCD_EBIT 2
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
ADCON1 = %00000000 ' Set PORTA analog
ADCINFO VAR BYTE
T1CON.0=0
TMR1H = 0
TMR1L = 0
ADCON1 = 0
ADC_READ:
PAUSE 500
timeloop:
ADCIN 0, ADCINFO
IF ADCINFO => 511 THEN GOSUB STARTTIMER
IF ADCINFO == 980 THEN GOSUB STOPTIMER
PAUSE 100
GOTO timeloop
STARTTIMER:
T1CON.0=1
STOPTIMER:
T1CON.0=0
GOTO ADC_READ
CLEARWDT
CalcTime.Highbyte=TMR1H
CalcTime.Lowbyte=TMR1L
Loope:
LCDOUT $FE, 1
LCDOUT "t:", CalcTime
Pause 500
Goto loope
GOTO ADC_READ
euh yeah, but the above will never do something else than reading the ADCs?
What do you want to do exactly?
Any idea of the time range between both voltage?
Looks like a kind of ESR measurement to me :D
Electron Spin Resonance ?
http://hyperphysics.phy-astr.gsu.edu...ecule/esr.html
;) nope, ESR meter... you know this kind of handy meter to find faulty capacitor?
pretty difficult for a rookie guy aha :)
Ok so in theory, you shouldn't have any problem with a 16Bits timer. BUT you'll need to compensate for the ADC sampling time.
What you could also do is to use a comparator interrupt...
Hi mackrackit
i tried this
but it doesnt stop counting for a defined voltage once it is triggered it does not stop for the final voltage.
Once i stop it i ll adjust the pauseus valueQuote:
loop:
adcin 0, adval
If adval => 500 then time
goto loop
time:
for X = 1 to 1023
pauseus 10
t = t + 1
If adval = 1000 then tcalc
next x
tCalc:
LCDOUT $fe, 2,"Time" ,":",DEC t
goto time
Anything missing? any suggestions?
You may want to explore the WHILE-WEND command.
