First timer...building a remote controlled vehicle
I have a science Olympiad tournament coming this month and for my project I am going to build a remote controlled vehicle. I can probably do the motor and turning part. But I need someone to help me with the transferring of data to the the pic chip in the controller (12F or 16F prob.) to the one the car (12F or 16F).
maybe using the technique found under the "five-button V2 transmitter and receiver (old)" heading at http://jap.hu/electronic/codec-v4.0.html
Please, please help me on this. Thank you by the way :D
okay, I will be using either a 12F683 pic chip or a 16F684. I have two zilog transreceivers and IR detectors and stuff. Here are the links for some of the things I bought:
transceiver - https://www.mouser.com/Search/Produc...X1810MV115TH29
Infrared Emitter/Sensor Assemblies SMD Slotted Optical Switch
https://www.mouser.com/Search/Produc...ey512-QVE00033
I will try to buy whatever you guys suggest as long as you have tried it before and you know that it works. Please help out.
The major thing I would need help with would be button debouncing as it does not seem to work with if then statements for me and how to send data to the another pic (either the 12F or 16F above) using the transceiver. Maybe code examples, links, and anything that can help me out would be great.
thank you all!
deadline? Jan 27th !!!! :(
Robotic control via TV remote control
I just found out about this website. So, this information may be too late to use.
On the other hand, your original post was on Jan 15, 2009.
Microchip has an application note, AN657, that shows you how to decode TV remote control signals. The application note includes source code.
You make a table of the decoded codes for the buttons you want to use.
Then write simple subroutines for each task you need to do.
