hi
I'm not new to pics but have a problem
i got new PC when i installed mcs pbp and tried to compile a simple program i get error (source file read only.msg) i have all original software
for any asistance i would be for ever greatfull
andrew
hi
andrew
New PC...
Maybe you moved the file you are working on from the old PC via CD?
Go to the directory where the file is located and check the properties, un-check the read only box.
the program i am trying to compile is one i created new simpily
start:
high 5
pause 200
low 5
goto start
it use to work but now i cant get it to work
i can save as project but not compile
thanks again
from andrew
Isall that it says?Quote:
Any other clues?
the only mesage i get is source file read only
i am running the same setup on another computer set up the same way runs fine
thanks andrew
ps i know i could use other pc but not the point should work on this pc same os same software
i have fixed problem i just included include 16f84a and it now compiles thanks for all your help
andrew
