Electroluminescent LCD backlight
Hi folks, for years I've been looking for simple economical DC/AC converters for EL backlights without using specialized ICs. The main problem with EL backlights is that they run off high AC voltage. I finally hit paydirt with a schematic from Nerdkits that runs off 5V:
http://www.nerdkits.com/videos/backlight
I'm including a pic of their schematic as well as a sample parts list I got from DigiKey.
For the two 150 Hz and 150 kHz signals, I used 555 IC timers using this tutorial from Guelph University:
http://www.uoguelph.ca/~antoon/gadgets/555/555.html
I've finished the two signal generators, the 150 Hz and 150 kHz signals are spot on. Now I'm starting breadboarding the EL circuit and will report back once complete.
Some of you have gotten these LCDs cheap on eBay but never got around to figure out how to get the backlights working properly, hope this helps.
Re: Electroluminescent LCD backlight
Hi Robert
Just wondering whether you managed to get any headway with this one? I am trying to do exactly the circuit. I have been using a TS555 for the high frequency side and a NE555 for the lower frequency side. It is for a battery powered driver for EL wire so the voltage will vary between 3.9V and 4.8V. Did you find out how the inductance relates to the outputted Voltage?
Cheers
You're lucky I read this, I've been away from the forum since I did this test.
Yes and no, I got the backlight working by playing with the timers. It wasn't lighting up as bright as I hoped, nor was the voltage going as high as necessary. But it did light up, so the circuit is good in principle.
I'll be getting back into this once I finish building a new batcave; hopefully by this summer.
That sounds good. I tried it again with a scope and couldn't get it working still. I think that I have bought inductors that are over- rated and I think this is the problem. I'm gonna order a range of 100uH ones with different current ratings and see how they work out. I also think maybe the 680pF capacitor is a little on the small side. Anyway, good luck on your bat cave
What is the rated current of your load?
The inductors presented in this thread are just RF chokes and not intented for SMPS circuit use.
If the inductor is saturated you may just burn the mosfet or the inductor itself.
ON time, Vcc, MOSFET On resistance, Inductance and Inductor resistor are the factors to consider for the current through the inductor.
Simple circuit but lots of math behind it.
An oscilloscope is a must for the checks.
Also, if you change places between MOSFET and Inductor and reverse polarity of the Diode, you can drop the second MOSFET. Just the polarity of Vout would be inverted.
This was my first foray into this sort of circuitry. I was just looking for something to light up these LCDs and that was the only circuit I could find.
If you can draw a better schematic to do this, I'd really appreciate it. Giving details on the parts needed would also be a huge help.
In other words, assume you are talking to a 10 year old. :D
in other words, assume you are talking to a 10year old. :D
*chuckle* At least you got some experience lately :D
Ron Marcus
Look on Microchip's website for a high voltage generator using a PIC. It is informative and pretty cool.
Looking under Application Notes - Voltage Regulation, I found this:
TB053 - Generating High Voltage Using the PIC16C781/782
http://ww1.microchip.com/downloads/e...tes/91053b.pdf
The only spec I see for the inductor is:
"Power inductors, in the range of 330 μH @ 0.655A, are common and readily available."
When I looked for "power inductors" at Digikey, I was faced with this:
http://search.digikey.com/scripts/Dk...er%20inductors
I selected "through-hole 330uH" and 31 items popped up, then sorting by Current and this item at 850mA was the most affordable over 655mA ($0.85 ea.):
http://search.digikey.com/scripts/Dk...me=811-2103-ND
I'll order a bunch in my next order and do some testing.
mister_e
You're only a 30 minute drive from here and don't forget I can run faster than you, even with my walker. :P lol
An excellent source of information (technical as well as pricing) on power inductors etc. http://www.coilcraft.com/
Googling for PC-016ATE, I made my way here via Wombat:
http://www.serialwombat.com/parts/LCD-107.pdf
mArms=2.9
Also got more information on what we should aim for:
Vrms=100
fEL=400Hz
This circuit is interesting:
http://www.simplecircuitdiagram.com/...mple-inverter/
http://www.simplecircuitdiagram.com/...e-inverter.gif
I just wouldn't know what to try as transformer to go from 5vdc to 100vac, nor how to control frequency at 400Hz.
I don't have many transformers on hand to fry.
Try this and let me know how it works out.
Attachment 5472
