I just tossed this code together to see if I could make a simple on-off remote for my Sony TV, but it doesn't seem to want to work. I used an IR receiver module to compare my PIC produced signal with two different remotes that work with the TV, and the signals are very, Very close, but something still isnt right. I can't really see a make or break difference with my analog scope, but I have an LED connected to the IR receiver and it flashes, where as my signal seems to make it stay on, or at least its blinking fast enough to make it seem that way. I'm using HPWM (I know, I know.. ) to modulate the signal by using its pin as the low side of the LED and using RB0 as the highside and output. Can anyone offer corrections on the code (or my method)? Thanks ahead of time!
Code:@ DEVICE pic16F648A, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF, BOD_OFF
CMCON = 0
CCP1CON.2 = 1
CCP1CON.3 = 1
PORTB.3 = 0
Timingvar VAR WORD
HPWM 1,127,40000
Timingvar = 2704
GOSUB Header:
SELECT CASE Timingvar.11
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.10
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.9
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.8
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.7
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.6
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.5
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.4
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.3
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.2
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
SELECT CASE Timingvar.0
CASE 0
GOSUB sZERO:
CASE 1
GOSUB sONE:
END SELECT
goto main:
Header:
LOW 0
pauseus 2400
high 0
Pauseus 600
sONE:
HIGH 0
pauseus 1200
LOW 0
Pauseus 600
sZERO:
HIGH 0
pauseus 600
LOW 0
Pauseus 600
