In TTL logic an input lower than 0.8 volts is seen as logic zero. Does this apply to pic inputs ports as well ? In the data sheet, I could not find any information regarding the voltage threshold level needed to trigger the high logic state on the input port.
I need to know which is the minimum voltage level capable to trigger an interrupt.
Thanks for the answer.
Al.
