16f877 generate pwm according 2 analog input
Hello everybody,
I am trying to make buck converter and control it with 16f877. The logic is simple. If the output voltage of the buck is higher than reference voltage the pwm duty cycle will decrease, if the output voltage is lower than the reference the duty cycle will increase. It seems very simple, but I couldn't be able to write the program:( I write but i doesn't work. I am new at pic programming. Help me please!!!
My crystal is 20MHz.
And it gives an error " ADC conversion clock period (1e-7) is possible invalid for device clock frequency" in proteus simulation.
DEFINE OSC 20
DEFINE ADC_BITS 8
DEFINE ADC_SAMPLES 50
TRISA=%00000011
TRISB=00
TRISC=00
TRISD=00
TRISE=00
Reference var byte
Voltage var byte
CCP1CON=%000011100
CCP2CON=%000011100
T2CON=%00000101 'timer 2 on, 1:1 postscale, 1:4 prescale
PR2= 49
CCPR1L=%00011001
get_reference:
ADCON1=%00000000
' Set LEFT Justification
' Enable ALL ADC's (using PIC16F87x as example)
ADCON0=%11000001
' Set ADC Channel 0 (RA0/AN0)
' Enable ADC Module
PauseUS 50
' 50uS Pause to allow sampling Capacitor to charge
ADCON0.1=1
' Start Conversion
While ADCON0.1=1:Wend
' Wait for conversion to complete
Reference=ADRESH
' Read 8-bit Result
get_voltage:
ADCON0=%11001001
' Set Fosc/32
' Set ADC Channel 1 (RA1/AN1)
' Enable ADC Module
PauseUS 50
ADCON0.1=1
Voltage=ADRESH
azalt:
CCPR1L=CCPR1L-1
arttir:
CCPR1L=CCPR1L+1
sabit:
CCPR1L=CCPR1L
main_loop:
Gosub get_Reference ' Get reference value
Gosub get_voltage ' Get voltage value
if Reference>Voltage then azalt
if Reference< Voltage then arttir
IF Reference=Voltage then sabit
goto main_loop ' Do it forever
pwm and SPI at the same time
Hello again,
For my buck problem, I found a good example. With little changes I applied to my circuit. Now it is working. This circuit was maintaining the voltage.It was infiinite loop.
Now, I want to use SPI module of 16f877 for TLC5941 led driver IC. It uses CLK, SDO outputs continuously. This should be infinite loop too.
May be it will be a silly question. But is there any way to use same pic for 2 different infnite loops? Do I have to use 2 pics. I can use, but if it is available I want to do it with one pic. Because I think to use rgb leds. And if I use 2 pics for one color, it will increse the total number of pics in my whole project.
